Results 1,281 to 1,290 of 2104
July 4th, 2021 08:48 AM #1281
July 4th, 2021 08:49 AM #1282
Bakit hinde katulad ng sa new Zealand or Hawaii na mga volcanoes dito pag pumutok yun Meron na lumalabas na lava? Iba ba mga volcanoes natin?
- 54,205
July 4th, 2021 08:51 AM #1283yes,
there are several types of volcanoes and volcanic eraptions.
ginugel ko. interesting.
hindi lang ako marunong pumutol at magdikit.Last edited by dr. d; July 4th, 2021 at 08:57 AM.
- Oct 2006
- 6,249
July 4th, 2021 12:21 PM #1284Mechanism of formation is different. hawaiian volcanoes are "hot spot" volcanoes. Source of magma is almost similar to mantle material or what is called "primitive". Not much water (not so explosive eruptions), hotter, low in silica and high in iron and magnesium (black and smoother lava), hence flows much easier. In contrast Philippine and New Zealand volcanoes are island arc type. Magma comes from partially-melted material under the crust caused by mixing of water. The water acts as a "flux", makes the melting point of the rocks lower. The water come from oceanic crust diving under another crust. The water makes our volcanoes more explosive, and because the magma comes form recycled rocks, its less-"primitive" and therefore has higher silica, lower tempearture and slightly lower iron and magnesium content (lava is lighter in color and more blocky).
July 4th, 2021 12:38 PM #1285
- 5,046
July 4th, 2021 12:50 PM #1286Oh, Mr. President.
EXPLAINER: Here's why you wouldn’t want to cap a volcano | Inquirer News
- 54,205
July 4th, 2021 02:46 PM #1287
July 4th, 2021 03:50 PM #1288
July 4th, 2021 03:59 PM #1289
- Oct 2006
- 6,249
July 4th, 2021 04:16 PM #1290Same as last year, violent, but I don't expect it to be of the same magnitude (I can still be wrong). Its giving off lots of gas and steam w/c means its not building up much pressure and its only been the last eruption. Compare yung video last Friday vs video nung 2020. Maiksi lang and maliit yung Friday.
Mga bulkan sa Japan, Pilipinas, Indonesia, Italy, New Zealand & South America are pretty violent when they erupt. Lots of explosions. Hawaii, East Africa and Iceland naman less violent to even quiet but can still be spectacular.
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
