Results 21 to 27 of 27
April 10th, 2019 01:52 PM #21
a. The cabinet is nowhere near a window. It's in an 'island' between my living room and dining area
b. Watercooling is likely to be ineffective as the ambient temp in the IT cabinet can reach close to 37°C. Two of my servers are only rated at 35°C max. ambient temp, and as mentioned previously, the one on top gets the brunt of it. Also, beyond the CPU, I can't watercool everything... RAM, chipsets, hard drives, etc.
This is the ambient temp reading for the last 36 hours in the area where the server in question is located. Notice that even during the wee hours of the morning, the temp barely goes below 34°C. It only goes down whenever the living room A/C is running.
This is the actual picture of the setup, taken a few minutes ago.
- Feb 2014
- 2,694
April 10th, 2019 02:00 PM #22how about putting your entire servers into a chest freezer
then run it at a fairly warm settings, dunno if that's possible though...
but i'm really interested on how to crank a car a/c compressor. but for different reasons
April 10th, 2019 02:22 PM #23
- Oct 2006
- 6,248
April 10th, 2019 02:50 PM #24
- Feb 2014
- 2,694
April 10th, 2019 03:02 PM #25
you got high ambient temps in the cabinet coz the CPUs/GPUs heat everything inside. so if you could watercool them then mount the radiators far away you'd drop the ambient temps inside the cabinet. you simply have to run 2 thin hoses. very neat. low power consumption too. i got lots of experience w/ watercooling from my overclocking days...
- Jul 2013
- 2,450
April 10th, 2019 03:09 PM #26
April 10th, 2019 03:50 PM #27
As a matter of fact, this is the direction I'm considering. The cabinet already has a 4-inch PVC pipe going to the attic. A custom/fabricated mini "split-type" A/C will be ideal. Control is through a thermostat and/or home automation.
As it is, with the room A/C off (a 2.5HP inverter split) the living room and dining room are just a few degrees cooler than my IT cabinet. I'm looking at having the cabinet actively cooled with the heat expelled through a condenser installed in the attic. That way, I don't inadvertently warm up my home and tax the existing room A/C.
I have three (3) servers now with the possibility to add more in the future. Is there a liquid cooling solution that can pool all servers' plumbing into one big radiator? I don't want three or more sets of hoses going in and out along with three radiators outside.
This is plan B. If it can be helped, I would like to dump the hot air outside the house (or to the attic). But not through ventilation. Doing so will create negative pressure inside the house and reduce the effectiveness of my existing room A/C.
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
