Results 1 to 10 of 27
April 10th, 2019 03:50 PM #1
As a matter of fact, this is the direction I'm considering. The cabinet already has a 4-inch PVC pipe going to the attic. A custom/fabricated mini "split-type" A/C will be ideal. Control is through a thermostat and/or home automation.
As it is, with the room A/C off (a 2.5HP inverter split) the living room and dining room are just a few degrees cooler than my IT cabinet. I'm looking at having the cabinet actively cooled with the heat expelled through a condenser installed in the attic. That way, I don't inadvertently warm up my home and tax the existing room A/C.
I have three (3) servers now with the possibility to add more in the future. Is there a liquid cooling solution that can pool all servers' plumbing into one big radiator? I don't want three or more sets of hoses going in and out along with three radiators outside.
This is plan B. If it can be helped, I would like to dump the hot air outside the house (or to the attic). But not through ventilation. Doing so will create negative pressure inside the house and reduce the effectiveness of my existing room A/C.
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
