Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
    Jun 2003
    #21
    the type of sealant you need is "acetic cure"
    this is the type that glass and window fabricators use
    how ever for your purpose you need the DOW CORNING brand. why? because it dries up faster and holds stronger than your regular brand x or y sealant
    cost for sealant (dowcorning brand) 100pesos
    cost of caulking gun (disposable type "plastic" good for 5-10 tubes)) 75 pesos
    (go to your suking aluminum and glass dealers)
    its pretty straight forward to repair an aquarium
    -drain it
    -make sure that the area were there is leak is dry by wiping with a cloth
    -use a blade or cutter to scrape off the existing sealant
    (if you find it tedious you can just put your sealant on top of the existing however we are aiming for a clean look that is why i recommend scraping off the existing adhesive)
    -before applying the sealant put masking tapes on areas that you dont want the sealant to adhere (sides near the leak)
    -after putting sealant use you thumb or index finger run it againts the place where u applied sealant to,from top tobottom or vice versa
    -in case there is excess application of sealant you dont need to remove it right away just let it dry and use a cutter or blade to remove it afterwards
    Hope this helps
  2. FrankDrebin Guest
    #22
    Leaking Aquarium.
    Dec 2003
    #23
    aha my favorite type of aquarium!
    Feb 2005
    #24
    Quote Originally Posted by yebo
    meron ako nakita aquarium 1 piece glass sya, rounded corners so there are no seams either on the sides or bottom. di ko ask price, for sure mahal yun
    last vacation sumakit back ko sa lintek na aquarium namin. clean ko sya so i had to remove all the stones (small black pebbles and bigger white pebbles.) e nung ibabalik ko na pinagalitan ako ni misis, bakit ko daw hinalo yung black saka white, yun daw black sa ilalim yung white sa ibabaw. hirap pala maging gold panner nyahahahaha! 5 hours ako nilalatigo ni misis habang pinipili ko yung white from black
    natawa ko dito ah!
    Jun 2003
    #25
    frankdrebin
    nice aquatank you got there and the choices of fish inside also are good
    however nakakatakot lang yan baka may kuryente :D
Our Aquarium Is Leaking
