with the project being described, the doubts were on the quality, time, and the cost. one aspect that was not discussed was flexibility for expansion or modification. with that in mind, steel framing and hardiflex construction is still the fastest, less cost, more flexible, earthquake resistant, fire safe and readily expandable not to mention easy to maintain if the members were bolted or screwed together. the flooring for the second to the rest upper floors can be made of ribspan with hardiflex floor substrate covered in carpet, vinyl tile, ceramic tile or hardwood floor planks. there is no need to worry about termites. no need for forms for poured in concrete aside from the foundation. less plaster finishing and readily paintable once the walls are installed. floor joists can be made of engineered trusses for longer spans, straightness and ease of joining using nuts and bolts or welding. there are no more readily available lumber due to deforestration. the only materials you can use are composites and metal. construction method somehow changed by the inavailability of the traditional building materials.
