Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jun 2006
    May gumamit ba ng program na ito? Effective ba in saving money? For those who are not familiar with it, its basically a scheme where Meralco charges you lower rates for night time (off peak) use of electrcity. Peak time is higher than the normal Meralco rate.
    I'm tempted to try t but am not sure if it will help me save.
    Here a link explaining it. http://www.meralco.com.ph/consumerca...esprogram.html
    Sep 2008
    effective eto if you will use airconditioning, ironing, and washing machine, during off peak.
    Jun 2006
    Naka time of use ka ba? If yes how big are the savings?
    ok san ito kung walang bayad ang convertion ng meter
    Jun 2006
    Reviving this thread. I applied for meralco time of use. Downloaded the application form and brought it to the nearest Meralco branch. I asked them to apply 6 months zero interest for the meter. I'm paying about 557 pesos a month for 6 months for the meter.
    After a month of use, my generation charge went down from 49.7% to 41.8%. Electrical consumption in kwh is still the same. Without changing our usage habits, 63.08% of our use is off peak and 36.92% is during peak. The only significant change is, we told the maids to do most of the laundry on Sundays. Come to think of it maybe we should tell them to iron on sundays.
    Even with the meter charge, my monthly ave electric bill went down by around 700 pesos. If I'll disregard the 557 peso meter charge, I would save around 1250 pesos.
    Oct 2011
    Pwede ito sa mga call centers or gumagamit ng ice thermal ni dunham bush.
    Aug 2011
    Page does not exist.
    Same as cheap Philippines Electric Rates. It does not exist. :D
    Jun 2006
    Here is the updated site:
    Meralco | Ang Liwanag ng Bukas
    Analyzing my bill further, I noticed that Meralco's share rose a bit. I guess its what they get for implementing this. So for Meralco this is a win win program. They get more money but the consumer can save.
    Its the generation charge that went down. I think, generation charge is what the power plants gets. Makes sense since if a lot of people adapt this scheme and adjust their consumption patterns, the plants may be able to maximize their efficency during off peak hours and minimize peak hour loads. Saves them fuel and increase efficency. They may even be able to keep peak plants off.
    Quote Originally Posted by userfriendly View Post
    Bro.,- how much(in percentage) are you saving now, vs. your historical electric bills?
    17.0K:out:
    For residential,- to qualify, you have to be >500KW-Hr per month.
    During the TOU peak hours, is the rate of electricity the same or more expensive than the rate of electricity for regular subscribers?...
    I am asking this to assess the chance that the TOU subscriber would end up paying more than the regular subscriber, given that there is no change in his schedule/habit on electricity usage.
    17.1K:chop:
    Jun 2006
    Target ko pa naman <400kWh. Sayang.
    sayang half lang kami ng 500 eh. alam ko ganito na rin sa US eh, kaya nagdedevelop sila ng appliances na may clock, like for example ref na nag-a-autodefrost lang pag off peak since malakas sa kuryente ang defrost.
    17.1K:chop:
    Up ko lang, hoping someone could answer this, based on his/her experience of running TOU for a few months....
    I am planning to apply for TOU,- and I am doing my benchmarking and due diligence.
    17.1K:chop:
    Mar 2012
    mag inquire nga ako, since one of our business operates 7 days a week. maganda ito kasi every sunday, 6pm-8pm lang ang considered Peak hours
    Jun 2006
    17.1K:chop:
    IIRC, for peak times, TOU rate is higher by around 1 peso per kwhr. So if your electrical load is concentrated during the peak hours and cant be moved to offpeak, you may end up paying more.
    TOU worked for me bec I run a 1.5 and a 2 hp aircon at night. We dont run the AC in the morning since we are out.
    Mar 2012
    Ha? its higher by 1 peso on peak times? Nge, i may not save at all if that is the case
    Thanks for the information bro.
    Yes, we run our AC units at night... I-delay ko na lang siguro ang pag turn-on, to 9PM...
    Also, our daily washing,- i advance na lang namin to 6AM-8AM....
    17.1K:chop:
    CVT feedbaack Kung malaki nabawas sa Meralco mo ha.
    Paano mga pala if Ang off peak eh start ng 9pm to 6 am then I turn on a/c at 7pm so two hours Lang ma charge ng peak and the rest off peak rate na?
    Sent from my iPad using Tapatalk HD
    Jun 2006
    Yes. The meter has seperate readings for peak and off peak. Your bill will also show your peak and off peak usage.
    Off peak ay 9pm to 8am Mon to Sat, bro...
    Yes, kung buksan mo AC ng 7pM (sa amin 6pm lang bukas na... hahaha!), peak rate ang charge sa iyo hanggang 9pm. And then off peak rate na starting 9pm......... up to 8am... Pero take note, super malakas ang konsumo mo for the first hour ng aircon dahil pinapalamig niya ang kuwarto... and then maintenance na lang ng temperature...
    Walandyo,- ginawa mo naman akong guinea pig... Dive na tayo rito...
    Thinking aloud: If I can save P500 a month in electric bills,- then ROI(vs. bayad ng meter et al) is about 6 months....
    17.1K:chop:
Meralco time of use program
