Results 31 to 33 of 33
October 19th, 2005 07:31 PM #32
Sir kimps, you will need a cleaning solution for that. You can try Trend Micro's Damage Cleanup Engine and Template. First, download the engine and the template from here:
http://www.trendmicro.com/ftp/products/tsc/tsc.zip
Next, download a virus pattern from here:
http://www.trendmicro.com/ftp/produc...ern/lpt899.zip
Extract both files into a single folder. Once you have extracted them, disconnect the machine from the network or the internet. Next, run sysclean.com. This will automatically detect, clean, and repair your infected machine. Just let the tool run until it completes the tast. After that, reboot the machine then run the tool once again to be sure.
Once you have cleaned the machine, you need to make sure that it does not get reinfected. First, make sure that your OS (Windows) has the latest Service Pack and Patches so that you will be able to patch all vulnerabilities on the OS. These are holes where the viruses gets in. Next, install an Antivirus software. You can choose Trend Micro's PCCillin. There are a lot of OEM copies for sale at Computer retail outlets. Just tell the vendor to give you the OEM copy. They are cheaper but still licensed.
October 20th, 2005 03:50 AM #33Originally Posted by ghosthunter
high idle RPM at engine start
