Results 11 to 17 of 17
- Nov 2002
- 1,326
January 13th, 2010 02:13 PM #11
January 13th, 2010 02:47 PM #12
ah oo, effective talaga pag high temp plus high pressure pa. heat will easily loosen mga tulog na oil same as kerosene and gasoline the better kaya lang medyo magastos.
muriatic acid, pwede siguro pero delikado. pati gamit na gagamitin mo baka matunaw.
January 13th, 2010 03:54 PM #13
- Nov 2002
- 1,326
January 13th, 2010 04:21 PM #14yung quote sa amin was yung KAESSER brand (gumagawa din ng air compressors).. banggit ng kuya ko nasa 1xx,xxx.xx something presyo...
nag inquire din sya sa clean city (dealer ng mga janitorial supplies and equipment like floor polishers, etc.. ).. di ko maalala price na banggit nya.. but much cheaper.. although specs ata magkaiba...
naghahanap pa kami ng alternative supplier kaya wala pa...
hmmm can this also be applied sa car wash? something like hot shower for the car? hehe..
January 13th, 2010 04:52 PM #15
Same principle sa car under wash using steam.
Meron dati sa Total North Fairview, car under was using KAESSER, ngayon wala na at gamit nila ngayon eh foam wash na lang
January 13th, 2010 06:03 PM #16
first, mechanical cleaning by scraping the dirt and grime off the floor and discarding it. second, chemical cleaning by some biodegradeable degreaser such as kleenol or simple green. but in the philippines, axion dishwashing cream or liquid followed by a rinse of hot water. flushing biodegradeable detergent to the storm drains or to the ground is acceptable if done sparingly. using gasoline, kerosene or other petroleum products is not only costly but is very dangerous. if somebody smokes around the area then the whole place would ble cleaned to ashes. if you use muriatic (hydrochloric) acid washes or etches the concrete if it was new in preparation for priming and/or painting but not degreasing. acid is very dangerous, corrosive, toxic and may damage the concrete and the reinforcing bars embedded in the concrete. use green way of cleaning that does not have a big impact on the environment
THE AUTO SPECIALIST
- Mar 2006
- 607
January 23rd, 2010 07:48 AM #17
Xiaomi E-Car
