Results 1 to 19 of 19
    Aug 2006
    Hello mga fellow tsikoters..
    hope every each 1 of you here are safe from the recent typhoon..
    anyway..question lang po..i just had a newly contructed house..then comes etong si typhoon maring...
    nagkakaroon ng moisture yung some parts ng walls namin..hinde naman lahat..pero may area siya na nag moist na kala mo basa pag hinawakan mo...
    ano kaya problema at solution sa ganun?
    TIA
    Quote Originally Posted by earthlyken View Post
    TIA
    You can paint the concrete walls with a water proofing chemical. This creates a waterproof barrier to prevent water from crossing through.
    Jul 2011
    1. Pictures for reference, in and out ng house kung saan nag moist
    2. Inform your contractor about the problem
    since bago ang house mo, meron yan warranty.
    meron ka bang katabing bahay kung saan nagkaroon ng moist ang wall mo?
    1. if yes, ung 2 pader nyo nagkadikit, ang solution dyan lagyan ng flashing sa ibabaw para ung tubig hindi papasok sa pagitan ng 2 pader.
    kung wala ka naman katabi, paulit mo ung water-proofing ng outside wall, baka nagkaroon ng hairline cracks kung saan pumapasok ang tubig.
    Pwede din mangaling sa roof drain, kung nagkarron ng bara or meron leak
    Feb 2013
    Elastomeric paint.
    Ayan, di ka kasi nag-invite ng mga tsikot forumers sa house warming nyo. :D
    One option is to use waterproofing sealant and/or elastomeric paint. Check first for hairline cracks and water seepage sources before sealing. If you seal it, baka gumapang lang yung water to another part and it will be harder to trace later on.
    Pwede rin, pag umuulan ng malakas, ilipat mo sa garage or balutan ng plastic yung bahay para di mabasa. :D
    Quote Originally Posted by siopaonatoasted View Post
    Elastomeric paint.
    less than useless.
    Sep 2009
    Yung sa amin naman sir ang nangyari gumapang yung tubig tapos nag bubbles yung paint. Ilang beses ko na inaakyat yung bubong namin at nilagyan lahat ng sealant pero wa epek pa din. Hayz!
    Oct 2011
    Sir GH, anong water proofing chemicals for walls? sa slab kasi ung waterproofing membrane ginagamit namin.
    Aug 2006
    May elastomeric paint napo yung labas...sun and rain ginamit kopo..triple coat nga ginawa nila..also were planning to remove the paint part sa mga nag moist then pahiran ng thoroseal tsaka mag paint ulit..do you think that will work?
    Look for "Concrete Sealer".
    Use it like paint but it's a clear liquid and also dries clear. It's function is to seal and block all the pores in concrete to prevent water getting through. Downside, if the wall develops a crack later, water will get through that particular crack.
    Waterproof membrane is actually the better solution IF you can still access the entire area that needs to be waterproofed. But it also means an extensive amount of work needed to be done to restore and hide the membrane.
    Jul 2011
    Quote Originally Posted by wezz_zzew View Post
    nakita mo na ba kung saan ang source ng leak?
    dapat analyze mo kung bakit ung tubig ulan ay hindi tumutuloy papunta ng gutter, then apply your solution.
    Aug 2006
    Sir GH...
    Do i need to pill off the paint where the moisture is? Before applying the sealer? Or i can just apply it directly on the area that has moisture in it?
    Aug 2006
    Also...do i apply it when the walls are dry? Or can i apply it while the walls are wet?
    Oct 2011
    Oo nga sir GH, mahal din ung water proofing membrane. Cge, try ko ung concrete sealer.
    Sep 2009
    Quote Originally Posted by Manilablock View Post
    Yun nga sir ang problem ko eh. Halos nalagyan ko na lahat ng sealant pero hindi ko pa din makita yung leak. Ang problema, 3rd floor bahay namin kaya mahirap akyatin during rainy days dahil pag nagkamali ako, wala talaga chance na mabuo ang mukha ko. Parang pinagpapawisan yung mga walls tapos pag naipon na, ayun, lobo ang paint.
    Jan 2009
    Consider also the possibility of a leaking water or drain pipe within the wall.
    The blueprint of your house would probably tell you if there are pipes in there along with their relative position.
    Like oj88 said, the water could be coming from leaking water pipes.
    Does the wall leak only during rainy days or even on clear weather days?
    It happened at my home when a plastic pipe started leaking and water started to seep out from the wall. After knocking down part of the concrete wall to access the leaking pipes, we found the pipes to have many pin-hole sized holes causing the water leak. Anyway, it was replaced and the wall restored.
    Sep 2009
    The leak only appears during rainy days. Planning to visit the roof this weekend to check every inch para masigurado na wala na talaga magiging leak. Mag leak test na din ako using waterhose para makita kung saan nagmumula. Thanks!
    Jan 2009
    Water has to be coming somewhere. Do the downspout drains run along the outside of the building or is integrated into the concrete walls or columns?
House walls creating moisture
