Results 1 to 19 of 19
    Oct 2011
    You can paint the concrete walls with a water proofing chemical. This creates a waterproof barrier to prevent water from crossing through.
    Sir GH, anong water proofing chemicals for walls? sa slab kasi ung waterproofing membrane ginagamit namin.
    Aug 2006
    May elastomeric paint napo yung labas...sun and rain ginamit kopo..triple coat nga ginawa nila..also were planning to remove the paint part sa mga nag moist then pahiran ng thoroseal tsaka mag paint ulit..do you think that will work?
    Look for "Concrete Sealer".
    Use it like paint but it's a clear liquid and also dries clear. It's function is to seal and block all the pores in concrete to prevent water getting through. Downside, if the wall develops a crack later, water will get through that particular crack.
    Waterproof membrane is actually the better solution IF you can still access the entire area that needs to be waterproofed. But it also means an extensive amount of work needed to be done to restore and hide the membrane.
    Aug 2006
    Also...do i apply it when the walls are dry? Or can i apply it while the walls are wet?
    Oct 2011
    Oo nga sir GH, mahal din ung water proofing membrane. Cge, try ko ung concrete sealer.
House walls creating moisture
