Results 1 to 19 of 19
    Feb 2013
    Elastomeric paint.
    Ayan, di ka kasi nag-invite ng mga tsikot forumers sa house warming nyo. :D
    One option is to use waterproofing sealant and/or elastomeric paint. Check first for hairline cracks and water seepage sources before sealing. If you seal it, baka gumapang lang yung water to another part and it will be harder to trace later on.
    Pwede rin, pag umuulan ng malakas, ilipat mo sa garage or balutan ng plastic yung bahay para di mabasa. :D
    Quote Originally Posted by siopaonatoasted View Post
    Elastomeric paint.
    less than useless.
    Sep 2009
    Yung sa amin naman sir ang nangyari gumapang yung tubig tapos nag bubbles yung paint. Ilang beses ko na inaakyat yung bubong namin at nilagyan lahat ng sealant pero wa epek pa din. Hayz!
    Jul 2011
    Quote Originally Posted by wezz_zzew View Post
    nakita mo na ba kung saan ang source ng leak?
    dapat analyze mo kung bakit ung tubig ulan ay hindi tumutuloy papunta ng gutter, then apply your solution.
    Aug 2006
    Sir GH...
    Do i need to pill off the paint where the moisture is? Before applying the sealer? Or i can just apply it directly on the area that has moisture in it?
    Sep 2009
    Quote Originally Posted by Manilablock View Post
    Yun nga sir ang problem ko eh. Halos nalagyan ko na lahat ng sealant pero hindi ko pa din makita yung leak. Ang problema, 3rd floor bahay namin kaya mahirap akyatin during rainy days dahil pag nagkamali ako, wala talaga chance na mabuo ang mukha ko. Parang pinagpapawisan yung mga walls tapos pag naipon na, ayun, lobo ang paint.
    Jan 2009
    Consider also the possibility of a leaking water or drain pipe within the wall.
    The blueprint of your house would probably tell you if there are pipes in there along with their relative position.
    Like oj88 said, the water could be coming from leaking water pipes.
    Does the wall leak only during rainy days or even on clear weather days?
    It happened at my home when a plastic pipe started leaking and water started to seep out from the wall. After knocking down part of the concrete wall to access the leaking pipes, we found the pipes to have many pin-hole sized holes causing the water leak. Anyway, it was replaced and the wall restored.
    Sep 2009
    The leak only appears during rainy days. Planning to visit the roof this weekend to check every inch para masigurado na wala na talaga magiging leak. Mag leak test na din ako using waterhose para makita kung saan nagmumula. Thanks!
House walls creating moisture
