Results 581 to 590 of 1411
- Mar 2014
- 169
July 20th, 2014 11:08 PM #581Meron nga pala kami mga kakilala na carpenters sa province who build houses there. Issue namin kasi baka di nila alam rules dito as well as the drainage system etc..
Posted via Tsikot Mobile App
- Sep 2008
- 142
July 21st, 2014 07:46 PM #582
July 21st, 2014 11:03 PM #583
July 29th, 2014 06:05 PM #584
P5000 for materials and P4000 for labor to prepare and paint one wall in a 25 square meter long area? What is done ba sa paint preparation?
Hindi ako makaintindi ng 2d layoutLast edited by _Cathy_; July 29th, 2014 at 06:08 PM.
July 29th, 2014 10:39 PM #585
- Mar 2009
- 823
July 29th, 2014 10:53 PM #587
July 29th, 2014 11:15 PM #588
ano po ba ang pipinturahan? wood or concrete?
basic steps:
1 - cleaning
2 - sanding
3 - plastering
4 - "lason" (neutralizer for concrete)
5 - primer application (1st - nth coating)
6 - finishing
7 - cleaning (tapos na... yehey!!!)
some of the steps are required to be repeated in order to achieve the desired "finish".
for most "small" painting jobs, material cost = labor cost.
kadalasan kasi, kahit sa owner na lahat ng gastos sa materials tapos
bayaran niya na lang 'yung taong gagawa (arawan), halos pareho lang talaga. HTH
July 29th, 2014 11:15 PM #589
5k for painting materials is just about right for a wall 9ft (3m) high covering a 25 sqm area. Assuming the 25sqm (5m x 5m) area is covered on ALL 4 SIDES by a 3m high wall. You might need minimum 2 Gallons flat latex for primer coat and minimum 4 Gal of semigloss latex (2 coats) for the final coat. Plus minimum 2 gallons of concrete neutralizer to prepare your surface since its only "roughed" finish, plus misc items. Labor cost, 4k? dont know, i can haggle for 2k siguro if rough finish. I'm no expert though. Hope this helps.
July 29th, 2014 11:27 PM #590
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
