Results 751 to 760 of 808
March 18th, 2024 03:32 PM #752
Imo you dont need insulation for a parking shed if its open on 2 or more sides anyway. If you want insulation on your long span roofing, Metalink and Puyat has variants with a 25-200mm foam insulation built in
March 18th, 2024 04:49 PM #754
Do you know of a contractor who do fire sprinkler heads relocation/adjustment? let say from pendent to upright.
- Feb 2014
- 2,698
March 19th, 2024 01:11 PM #755
that's my open shed, summer of 2022. i'll be installing double-foil insulation on that shed. tama si boybi, it's radiation, kaya meron foil layers. same reason why thermos bottles are mirrored inside, to reflect back the radiation
Ok ba onduline sa typhoons? Pwede tapakan in case need maintenance?
pwede yan. i think it needs to use more fasteners than metal roof though. just use 4x4 traction boards to spread the load if you wanna send someone up there to step on the onduline
speaking of summer. i just tested Campbridge CeramiCoat paint. it's just 5c cooler than ordinary white paint. that's not significant
- Mar 2024
- 7
March 29th, 2024 11:29 AM #757Hello! Can you recommend where to get solid wood planks and doors? For doors, ung may nag ooffer ng kamagong and narra besides the usual mahogany and tanguile.
March 29th, 2024 01:53 PM #758
Look into imported species like beech & oak should you plan lighter natural shades. Walnut for darker ones. These might end up costing you less than illegally sourced local exotic timber. Just dunno where to point you up the capital.
Sent from my SM-S901E using Tsikot Forums mobile app
March 30th, 2024 11:42 AM #759
Good Narra is very hard to find now. What is readily available now warps and tends to have imperfections. The best Narra could be found from reusing old Narra from demolished houses since these are done warping and are usually wider. If you have time, you can buy new Narra and let it warp for some time until the moisture content drops. If you have time and a lot of money, you can call house demolition companies and ask if they have been recently able to extract good Narra, this needs a good contractor to finish and install.
You can get Burmese Teak as an alternative. I cant recommend a supplier for either because these tend to be.......
March 30th, 2024 11:43 AM #760
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
