Page 76 of 81 FirstFirst ... 2666727374757677787980 ... LastLast
Results 751 to 760 of 808
    #751
    Quote Originally Posted by Vodka View Post
    better heat insulation yung SRC panel, right?
    btw i'm going to build a small parking shed. what can you say about onduline roofing? no need to use foam/foil insulation like you would on a metal roof, right? it's just gonna be for the car and i just don't wanna feel the heat while working on the car
    Ok ba onduline sa typhoons? Pwede tapakan in case need maintenance?
    Signature
    Jan 2012
    #752
    Imo you dont need insulation for a parking shed if its open on 2 or more sides anyway. If you want insulation on your long span roofing, Metalink and Puyat has variants with a 25-200mm foam insulation built in
    #753
    Quote Originally Posted by viper888 View Post
    Mainit pa din ang radiated heat from the roof kahit open all sides, unless sobra taas ng roof.
    Signature
    Feb 2019
    #754
    Do you know of a contractor who do fire sprinkler heads relocation/adjustment? let say from pendent to upright.
    Feb 2014
    #755
    that's my open shed, summer of 2022. i'll be installing double-foil insulation on that shed. tama si boybi, it's radiation, kaya meron foil layers. same reason why thermos bottles are mirrored inside, to reflect back the radiation
    pwede yan. i think it needs to use more fasteners than metal roof though. just use 4x4 traction boards to spread the load if you wanna send someone up there to step on the onduline
    speaking of summer. i just tested Campbridge CeramiCoat paint. it's just 5c cooler than ordinary white paint. that's not significant
    #756
    Baka dumulas yung traction board sa roof.
    Signature
    Mar 2024
    #757
    Hello! Can you recommend where to get solid wood planks and doors? For doors, ung may nag ooffer ng kamagong and narra besides the usual mahogany and tanguile.
    #758
    Quote Originally Posted by thechamp View Post
    Look into imported species like beech & oak should you plan lighter natural shades. Walnut for darker ones. These might end up costing you less than illegally sourced local exotic timber. Just dunno where to point you up the capital.
    Sent from my SM-S901E using Tsikot Forums mobile app
    Jan 2012
    #759
    Good Narra is very hard to find now. What is readily available now warps and tends to have imperfections. The best Narra could be found from reusing old Narra from demolished houses since these are done warping and are usually wider. If you have time, you can buy new Narra and let it warp for some time until the moisture content drops. If you have time and a lot of money, you can call house demolition companies and ask if they have been recently able to extract good Narra, this needs a good contractor to finish and install.
    You can get Burmese Teak as an alternative. I cant recommend a supplier for either because these tend to be.......
    Jan 2012
    #760
    Wow, whats the color of the roof? White or darker colors make a significant difference
House Construction
