Results 711 to 720 of 808
July 29th, 2023 07:58 AM #711
Do you mean a fence as high as a firewall? For me palitada is enough. Painting it with a quality brand would be better for aesthetis. Pwede rin pahiran mo waterproofing like boysen plexibond konting dagdag gastos na lang naman yan.
Mas mabuti na ito ang gawin mo kaysa move away a bit kasi ending nyan mas lalong exposed ang wall mo to rain at mas lalong mamamasa sa loob.
But the question is kung yard naman pala sa side mo why waterproof pa? Dahil uulanin din naman ang side mo.
- 54,216
July 29th, 2023 11:24 AM #712ask the authorities or the homeowners' association, if there are laws regarding "sagaran nang bahay sa property line".
should you decide for the 600 mm setback, you can erect a fence, to mark your property line.
if the other side of the firewall is not weather-sensitive naman, there would be no need to water proof it.
happy building.
July 29th, 2023 11:09 PM #713
Don't do that....This is what we have done for those who've had it w/ firewall troubles. Note the wall is windowless to pass easement restrictions; the roof is gutterless & the rain just hits the trench. Will never leak, no maintenance...& you'll have access to trench-cleaning. Build & forget.[emoji16]
Sent from my SM-S901E using Tsikot Forums mobile app
July 29th, 2023 11:24 PM #714
I personally never wish to do periodic maintenance call-backs. I will never do gutters w/in firewalls, nor firewalls w/o longspan cladding.
Waterproofing mentioned will need a lot of luck, would almost always fail & require periodic reapplication. I'd rather humbly decline such work.
- 54,216
July 30th, 2023 12:32 AM #715
July 30th, 2023 12:53 AM #716
Cure is fine, prevention best. Right, doc?[emoji4]
July 30th, 2023 10:21 AM #717
Pagnanalo ako sa lotto, papagawa ako ng bahay na walang firewall [emoji4]
July 30th, 2023 12:18 PM #718
Hehe...& should you plan roofdecks(worse than firewalls), roof em. [emoji4]
July 30th, 2023 03:46 PM #719
July 30th, 2023 07:18 PM #720
Gotta respect nature. Fighting it is bad gambling. The house always wins.[emoji38]
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
