Page 54 of 81 FirstFirst ... 44450515253545556575864 ... LastLast
Results 531 to 540 of 808
    Sep 2010
    #531
    How many cars can fit sa 150 sq m area na pahaba. Width is 2 cars.
    Sent from my SM-M127F using Tapatalk
    Would they use the whole lot just for parking? if so, then kasya 12 car. If may kasamang house, it would largely depend on the house layout. At least 1 car or maybe a 2 car garage with the house kasya.
    Sep 2021
    #532
    Hirap lang diyan for the vehicles in the back if you pack it to capacity.
    It may be a better idea to just reduce the total number of vehicles, and park them perpendicularly (like sa mall) then have a single driveway para makalabas lahat without needing to "shuffle" them.
    #533
    errr,
    why are you asking, po?.
    It's the parking in my Lola's house. She said the garage is exactly 150 sq m from the gate to the back wall (?) of the property. It's 2 cars wide. Tama computation niyo na 12 cars, so the parking is 2x6. Hindi nga lang pwede i swing wide open yung door ng car parked sa side ng wall. My cousin and I were discussing how many cars used to fit there when cars were still NORMAL SIZED. I recall 10 to 12 and he said less daw. I WIN
    Anyway, it's kinda sad because there are discussions about selling my Lola's house
    Quote Originally Posted by Miles_on View Post
    Yun lang talaga ang hassle, malas pag nasa dulo yung car, it's like tetris Sa family namin they always park inside when visiting lola, that's one reason why I prefer street parking
    #534
    It's the parking in my Lola's house. She said the garage is exactly 150 sq m from the gate to the back wall (?) of the property. It's 2 cars wide. Tama computation niyo na 12 cars, so the parking is 2x6. Hindi nga lang pwede i swing wide open yung door ng car parked sa side ng wall. My cousin and I were discussing how many cars used to fit there when cars were still NORMAL SIZED and before my Lola had another bodega constructed there. I recall 10 to 12 and he said less daw. I WIN
    our parking driveway is a smaller version of that: fully loaded, it can accomodate five cars bomper-to-bomper, and two cars to the side pockets. most of the time, however, there're only four cars parked.
    i sometimes hop-and-drive seven times in-and-out, 'ala tetris, to get out the car i want to drive that day.
    we are also particular about the brightness of the back-up lights. a foot inside the greenery, are a concrete wall on one side, and un-yielding kamiases on the other side.
    imagine our driveway during fruiting time... "take all you want... please!"
    #535
    Pano pala palitan yung mga roofing insulations na parang aluminum foil na may bubble? Nalulusaw na yung sa garahe namin, kapangit tignan.
    Signature
    Jan 2012
    #536
    You can ask either Metalink or Puyat Steel as they both have insulated long span roofing. You can contact metalink directly but you probably need to find a reseller for Puyat Steel
    It can attached on the existing purlins. The insulation of the roof can be between 25-200mm in thickness. You can probably go on the thinner side since its a garage
    #537
    Quote Originally Posted by viper888 View Post
    Do you mean papalitan ko roof ko just to have the insulation replaced?
    Signature
    Jan 2012
    #538
    The insulation is riveted between the purlins and the metal roof. A contractor can remove the roof, install the roof insulation, and reinstall the roof. We typically use 12mm PE foam with aluminum foil on both sides.
    I misunderstood that you wanted to change the entire roof
    Jan 2016
    #539
    You can put another layer on the riveted purlins to cover it. Actually this is the proper way to do it, rather than inserting it between the roof and the purlins. You can Google check how it works.
    Sep 2005
    #540
    yung ganyan namin sa garahe sinira nang ibon tapos binabahayan nila..
House Construction
