Results 451 to 460 of 808
- Mar 2013
- 6,160
July 29th, 2022 12:05 PM #451Yes. Double checking the engineering plans with a 3rd party. But overall should be relatively straightforward.
After ghost Month i want to do the work already.
Sent from my SM-G998B using Tsikot Forums mobile app
BANNED BANNED BANNED
- Sep 2015
- 13,917
July 29th, 2022 10:37 PM #452
cathey napanuod ko ngayon sa news. Yung mga ancestral house sa vigan walang nasira ang titibay!!!!
ang sabi ng architect "stepped foundation wall" Hindi daw malalim pero load bearing daw yung wall??? Hindi daw kagaya ng current na convetional na mas madali daw mag collapse? Paging travahnas can you explain this. Why is the civilizational wisdom of ancestral homes is earthquare proof vs the current ?????
Parang covid din = its the civilization wisdom ang effective.
Antayin ko ipost sa youtube ipost ko dito yung video ng interview.
EDIT : ito na fast forward 1:00:11
- Jun 2011
- 1,235
July 30th, 2022 01:45 AM #453
July 30th, 2022 12:20 PM #454
Curious lang, what steel reinforcements does the plan call for, for that big an overhang? Nakakatakot, baka mabali kapag may earthquake
- Mar 2013
- 6,160
July 30th, 2022 01:45 PM #455Good question. Am not an engineer though cantelevers are common and not much of an engineering problems nowadays. Just good and verified math hehe.
Let me ask.
July 30th, 2022 03:48 PM #456
Design limits(key word) will be dictated by load, deflection, seismic & safety criteria. A properly thought out reinforced concrete overhang should be no weaker than say an equivalently loaded simply-supported beam.
Sent from my SM-S901E using Tsikot Forums mobile app
July 30th, 2022 10:16 PM #457
Makes sense, but still curious, will the usual rebars or steel beams be used? Or are there specially fabricated steel "skeletons" or concrete mixes, for these far reaching overhangs? Or does the roof overhang provide additional support. Sorry didn't do well in my physics class. [emoji16]
July 31st, 2022 01:46 AM #458
Many variables & ways. Commercial rebars come in varied yield strengths(G40*40kpsi/G60*60kpsi), sizes & lengths. Concrete strength is in direct proprtion to cement factor(weight or bags) in a given volume, usually in m³...& there are additives that tweak specific characteristics. These are for your regular reinforced concrete.
Alternative ways for reinforced concrete to achieve longer spans, slimmer sections & limit deflections are pre-stressing & post tensioning. These are specialized services your structural engineer can advise you on.
Re the role of individual structural members, they all are factors, primary or secondary, to the stability of the structural framework as a whole when subjected to varied magnitudes & directions of dynamic & static forces thru axes X,Y,Z.
August 4th, 2022 09:50 PM #459
Pasingit
How much na pagawa nang house design/plan sa mga contracror kasama structural + bill of materials + project specs + electrical for 200sqm and above na floor area?
Me napagtanungan ako nasa 80k na for 200sqm and below sa Bulacan area. Need ko lang nang comparison.
Tia.
August 5th, 2022 08:03 PM #460
Pwede ba directly i-swap ang water pump to an inverter pump? Need pa ba ng pressure tank if naka inverter na?
Signature
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
