Page 40 of 81 FirstFirst ... 3036373839404142434450 ... LastLast
Results 391 to 400 of 808
    #391
    What's comprises the mechanical part? ...
    HVAC, ductwork, refrigeration, lifts, motorized systems, etc...
    Sent from my SM-S901E using Tsikot Forums mobile app
    Jun 2015
    #392
    Kitchen sink drains slowly. Newly replaced ang tubo from the strainer until the p-trap. We have no grease trap.
    It seems to me wala hangin sa tubo. Sometimes magde-drain ang I'll see bubbles coming up from the strainer.
    Ano dapat ang ipagawa sa tubero? Nung ni-replace ang p-trap may natanggal na ball of sebo from the pipe so I thought yun na ang problem. Apparently, meron pang iba probably deeper down the drain pipes.
    Social media made y'all way too comfortable with disrespecting people and not getting punched in the face for it. - Mike Tyson
    #393
    when this happened to us,
    the clog was traced to the segment of pipe about 5 feet distal to the water trap.
    grasa, hair, and other slow-bio-degradeables.
    Mar 2004
    #394
    There are people who specialize in clearing blocked pipes ... maybe you can find them on FB ...
    #395
    Always install vents to provide atmospheric pressure into the waste system. This is often overlooked by self-taught plumbers.
    One hack on clogged sinks, use your palm to rapid pump onto the strainer. Make sure the sink has water about half or an inch high when your hand pumping.
    #396
    This is what I do. Learned it from my wife when I saw her doing a CPR like chest compression sa drain. Now I always do it basta mabagal ang baba ng tubig.
    I heard a plunger will also do the trick. But my hand is enough.
    Mar 2013
    #397
    Plain render. No materiality yet. Gonna change some windows to make them floor to ceiling. But this is the base look.
    Its a 4 bedroom house with some nice views which i want to take advantage of.
    The property is on a slope so no choice but to build multi level.
    Starting soon. Hopefully! received_387963073211495.jpgreceived_5217300648350993.jpgreceived_376903667881012.jpgreceived_410742800851407.jpg
    Sent from my SM-G998B using Tsikot Forums mobile app
    Sep 2005
    #398
    Nice house there! Congratulations!
    Mar 2013
    #399
    Will change the windows in many areas. Dont like the casement look.
    The glass windows near the pool will be changed to look like this. img-ab60db1540de99a6478eba81b9388ebc-v.jpg
    Mar 2013
    #400
    Heres a render of the main kitchen and living area. The open plan intent is to maximize the view and connection to the outdoor spaces. img-f35c358557e98f0aba5cf7b7b73e9153-v.jpgimg-4a7c8ab72b353ab645995a0ab0857e89-v.jpgimg-38c1cf449fea82ef31e2ab968a48ff7a-v.jpgimg-cd7e92c41f063cfbbe5df6334279ca1f-v.jpg
House Construction
