Page 77 of 91 FirstFirst ... 276773747576777879808187 ... LastLast
Results 761 to 770 of 908
    #761
    if you don't mind the aesthetics.
    put old tires against all sides. then get another tire, put it on the ground, then get some wood with dimensions big enough such that it will fit in between all those side tires and not slosh around. then clamp the generator on that wood.
    during my acoustics class.. we ventured into egg trays/cartons... but i wasnt interested...i was more into robotics then 😁 before drone era was good but now im not as savvy..
    Aug 2003
    #763
    ^ i was thinking more along the lines of acoustic, non-flammable foam sir, pero solve ko muna yung vibration.
    Hindi naman po namin isasara yung doors while the genset is on for better ventilation
    Mar 2004
    #764
    Paps... poor ang ventilation? ... mag overheat yan... yung exhuast pipe lagyan mo ng extension palabas... dapat maganda ventilation...
    Noticed this also ... poor ventilation ... and the exhaust pipe has to be larger ...
    Aug 2003
    #765
    Would putting an industrial fan inside help? Yung exhaust pipe extended naman palabas, and hindi nakafix sa genset, tinutok lang dun yung tambutso.
    #766
    mga sirs patanong naman. i'm planning to add some wood planks on the base of the genset house para mabawasan yung vibration. Plano ko is just enough wood so that the base rests on the wood, and nakaangat yung mga gulong.
    OK na kaya coco lumber or scrap plywood?
    mas maganda sana yung naka anchor bolt ang gen-set mo without the wheels on a solid flat floor (must be same level on all 4-corners).
    to lessen the vibration meron din nabibiling hard rubber para ilagay on top of the solid flat floor bago higpitan ang anchor bolt.
    agree din ako sa extension ng exhaust pipe para iwas overheating... ideal kung meron insulation material na pwedeng ibalot sa exhaust piping/muffler (ewan ko lang kung meron kay bro gm ito).
    Jul 2013
    #767
    Industrial fan would be an overkill. Just Put an exhaust fan to draw how air out.
    Aug 2003
    #768
    Thanks for the comments sirs, i'll see if i can get something done over the weekend
    #769
    Meron bang nabibiling less than 10KVA na GENSET na:
    - diesel
    - 1800 rpm
    - liquid cooled
    - brushless alternator
    - OK lang kahit CHINA engine (or clone)
    TIA
    Jun 2011
    #770
    Quote Originally Posted by narmenia View Post
    - diesel
    - 1800 rpm
    - liquid cooled
    TIA
    Meron din...
    Pero better get nalang 15kva kunti nalang difference kasi sa 10kva....
    Bnew 250k Good for standby Use
    Genset use for Contineous 24/7 Operation
    Bnew 350k
Generator sets
