Results 461 to 470 of 908
July 22nd, 2014 07:10 AM #462
sir i check the specs and pics.. kung ganyan kalakas sa fuel yan... IMO mag china ka nalang... ilan araw lang para ka na din bumile ng china genset.. yung 6.2kva nasa 30k lang po yan...
get a bigger rating genset nalang para sigurado ka tumatakbo lang ito ng less than 50% ng kanyang rating... para hindi hirap ang generator mo...
Ang mga ganyan genset po kasi HINDI po matitibay yan... pag gagamitin mo na dun mo palang malalaman barado na pala noozles etc...
- Jul 2004
- 241
July 22nd, 2014 07:40 AM #463
Pre, alin sa mga sinabi ko ang malakas sa fuel? I am considering this 3 units now:
1) Elemax SH3200 (2500watts nominal) = 1.42 liters/hour (P1,870/24hours)
2) Honda EP2500CX (2300watts nominal) = 1.47 liters/hour (P1,941/24hours)
3) Elemeax SH07D Diesel (50%load is 3250watts nominal) = 1.69 liters/hour (P1,833/24hours)
I find their fuel consumption quite good already. Anong China brand will give me much better fuel consumption? Also, note that my nominal consumption will run at around 1600 watts only (I said mga 2000watts to give it some allowance baka may dagdag ako) so I think all three gensets above can easily handle my requirements.
Would you still go for China? Which particular brand/model and why? May I know its liters/hour? Thanks
July 22nd, 2014 08:33 AM #464
You shouldn't rely too much on the specs. It's like buying a car based on specs. Admittedly, there are much fewer generator set users compared to cars so it's very hard to get actual reviews from users. So best bet would be to buy from reputable sellers and get a reputable brand.
July 22nd, 2014 08:34 AM #465
July 22nd, 2014 11:08 AM #466
Yung Cummins genset namin na 45kva consumed on around 140-160li of diesel during the almost 4 days of power outage caused by typhoon Santi last year. Walang patayan yung genset. During the day kasi we need the electricity for the business, and during the night naman for the house. So less than 2li/hr lang pala ang consumption kahit 45kva na?
Signature
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 22nd, 2014 02:53 PM #467Uls, glen, can you pls pm me price for 10 kva diesel generator, silent type with wheels for easy transport. Can be loaded or pulled by my truck if needed. 1800 rpm, 230 volts, 60 hz, single phase.
My load will be 120 units of 15 watts led tube, 18 units electric fan about 90 watts each, printer, 3 computers and credit card terminal. No aircon load. I figure it's about 5 kW x 2 so about 10 kva. Tama ba?
- Jun 2006
- 2,605
July 22nd, 2014 02:55 PM #468Sorry double post.
Btw, can you pls include fuel consumption figures, how many litres of oil it needs, weight and other important info.
Thanks.Last edited by userfriendly; July 22nd, 2014 at 02:58 PM.
July 22nd, 2014 11:25 PM #469
ask ko lang ilan po temperature?
hula ko 45 lang he.he.. halos on idle lang yan.. he.he...
yung unit nyo sir malamang running only at less than 25% of its standby rating...
yung isang unit namin... 83kva Cummins din.. running between 60 up to 90percent of its standby rating... consumed 200 liters of fuel in 25 hours non stop operation....
July 22nd, 2014 11:30 PM #470
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
