Results 101 to 110 of 182
January 13th, 2017 10:47 AM #101
Bro Cvt, gawin mo na 3, pick up-in ko sa bahay mo pag mwron na 😃
DriveFastDieHappy
January 13th, 2017 12:00 PM #102
Sige bro.,- 3 na kaagad...
Pupuntahan ko na mamayang gabi ang aming Ophthalmologist at Optometrist,- kung mayroon na silang maipre-prescribe na lens with x-ray vision...
Suwerte talaga ni bro.Superman-CK sa Subic...
_/_/_/
31.5K _/_/_/_/_/_/_/_/_/_/
January 13th, 2017 07:18 PM #104
January 23rd, 2019 06:46 AM #105
Does anyone know where I can have my frame repaired? I went to several optical shops already at the mall and they said that they can't repair it anymore. It's only screw issues that they can repair. My eyeglasses broke at the hinge ata.
- Mar 2010
- 2,257
January 23rd, 2019 07:38 AM #106Try P. Paterno, Quiapo that is the mecca of eye glasses.
Sent from my ASUS_Z017DA using Tapatalk
- 52,731
January 23rd, 2019 08:51 AM #107flipo is right.
take a walking tour of that area.
despite the seeming simple-ness of the establishments there, a peek at their back rooms and you will be astonished at just how busy they are. i suspect, some of the name-brand opticals at the malls, outsource their jobs to these simple places.
your type of repair is usually a "while-you-wait" thing. few minutes only. and they charge shamefully cheap. last time i went there, years ago, the lady was even hesitant to charge me.
if the folks there can't fix your frame, nobody in the country, can.
good luck.Last edited by dr. d; January 23rd, 2019 at 10:42 AM.
- Jun 2015
- 2,751
April 7th, 2021 06:07 PM #108Has anyone experienced na pinalitan o ni-repair ng optical shop ang eyeglasses nila after nagka-defect in less than a few months?
I bought my frame and lenses last December 2020 from one optical shop. Now (4 months pa lang), nade-detach na yung metal part ng frame that holds the lens. I think it needs a strong adhesive or perhaps even solder para maibalik.
And since progressive itong lenses, it's either repair the frame o replace with the same frame.
April 7th, 2021 06:36 PM #109
Similar but not the same. Lens issue ang defect. Progressive as well. Somehow they couldn't get it right so they replaced twice in a span of 2 months.
Sent from my SM-N986B using Tsikot Forums mobile app
- 52,731
high idle RPM at engine start
