Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 101 to 120 of 182
    Feb 2005
    #101
    Bro Cvt, gawin mo na 3, pick up-in ko sa bahay mo pag mwron na 😃
    DriveFastDieHappy
    #102
    DriveFastDieHappy
    Sige bro.,- 3 na kaagad...
    Pupuntahan ko na mamayang gabi ang aming Ophthalmologist at Optometrist,- kung mayroon na silang maipre-prescribe na lens with x-ray vision...
    Suwerte talaga ni bro.Superman-CK sa Subic...
    _/_/_/
    31.5K _/_/_/_/_/_/_/_/_/_/
    Pasama na rin sana Sir CVT.
    #104
    Heto nga bro at kinukulit ko ang aming Ophthalmologist at Optometrist, at sinabi ko nang iyong bigshot ng Last Frontier ang nagre request.😉
    Kunghindi no pass siya for the underwater sea adventure.... 😄
    Gagawan daw niya ng paraan.. 🤓
    #105
    Does anyone know where I can have my frame repaired? I went to several optical shops already at the mall and they said that they can't repair it anymore. It's only screw issues that they can repair. My eyeglasses broke at the hinge ata.
    #106
    Try P. Paterno, Quiapo that is the mecca of eye glasses.
    Sent from my ASUS_Z017DA using Tapatalk
    #107
    flipo is right.
    take a walking tour of that area.
    despite the seeming simple-ness of the establishments there, a peek at their back rooms and you will be astonished at just how busy they are. i suspect, some of the name-brand opticals at the malls, outsource their jobs to these simple places.
    your type of repair is usually a "while-you-wait" thing. few minutes only. and they charge shamefully cheap. last time i went there, years ago, the lady was even hesitant to charge me.
    if the folks there can't fix your frame, nobody in the country, can.
    good luck.
    Jun 2015
    #108
    Has anyone experienced na pinalitan o ni-repair ng optical shop ang eyeglasses nila after nagka-defect in less than a few months?
    I bought my frame and lenses last December 2020 from one optical shop. Now (4 months pa lang), nade-detach na yung metal part ng frame that holds the lens. I think it needs a strong adhesive or perhaps even solder para maibalik.
    And since progressive itong lenses, it's either repair the frame o replace with the same frame.
    Dec 2004
    #109
    Similar but not the same. Lens issue ang defect. Progressive as well. Somehow they couldn't get it right so they replaced twice in a span of 2 months.
    Sent from my SM-N986B using Tsikot Forums mobile app
    #110
    the small tornilyo slowly unscrewed itself and finally fell away?
    bring it to the store you bought it from.
    sometimes, the repair is so simple...
    they will probably not charge you.
    tornilyos are so cheap...
    might i inquire,
    is the frame a brand name?
    Jun 2015
    #111
    might i inquire,
    It's a no-name but not really cheap half-rim metal frame with plastic temples.
    Unfortunately, it's not a simple screw replacement doc. Yung metal frame nito kasi 3 parts that are stuck together. There's the main frame where the "eyebrow" and the hinges are connected to. Ang part na nagho-hold ng lens at nose pad is a separate metal frame na nakadikit (soldered or glued?) lang dun sa main frame. There's 1 such "sub frame" for each eye.
    So siguro sa kaka-flex ng frame with daily wear and removal, bumigay na yung adhesive nung sub-frame sa left side. Nag-start pa lang sa corner but I'm sure it will only worsen over time.
    No way would I have known na may design flaw itong frame. All I was concerned with was that the temples are plastic due to my allergy to metals in jewelry. To think that I've been more careful than usual with this pair.
    #112
    dalhin nyo po sa optical.
    i suspect, the solution is easier than we can imagine.
    for allergy,
    go titanium.
    "hypoallergenic."
    Jun 2015
    #113
    Quote Originally Posted by thephantom View Post
    If optical shops can replace progressive lenses I hope they can replace frames (which is cheaper) as well.
    I'll give the shop a call tomorrow. I do hope warranty covers the frame.
    Jun 2015
    #114
    for allergy,
    go titanium.
    "hypoallergenic."
    Giving them a call tomorrow.
    Hmn, I didn't know that about titanium. Thanks.
    Dec 2004
    #115
    Hopefully you get them replaced. If not, change shops. Recently, about 6 months or so, I availed of Owndays' memory metal frames. It's the one that they demo na you can fold and twist and it springs back to shape. Been enjoying them.
    Sent from my SM-P205 using Tsikot Forums mobile app
    Jun 2015
    #116
    They replaced the frame, no questions asked. Fortunately, they still had the same frame brand and model but in black (the one I had was gun metal). Their policy is 6-month warranty with one-time replacement. I hope this replacement is sturdier than the first.
    Sent from my Nokia 6.1 using Tsikot Forums mobile app
    found the lightest frames from owndays and its like 9ish grams.
    #118
    lenses on frames,
    or
    temples and bridge on lenses?
    lenses on frames,
    or
    its full frames not rimless. i'm guessing the weight is without lenses.
    owndays service is pretty darn good.
    #120
    the limiting factor in eyeglasses is the lens.
    at times, the establishment has no stock of the required grades, and has to order them pa.
    blessed are those with simple grades of their eyes.
    the last time i had glasses made, because my old frame got broken,
    i brought my old lenses; it took them a few minutes only, to grind them to size and install them in my new frames.
eyeglass lens & frames
