Results 11 to 20 of 26
March 29th, 2011 09:33 PM #11
- Oct 2008
- 944
March 30th, 2011 02:37 PM #14
- Dec 2007
- 7
March 30th, 2011 06:02 PM #15
March 30th, 2011 07:27 PM #17
March 30th, 2011 08:07 PM #18
OT: ihi lang ba need sa drug test o kailangan jebs din?
may health test din ba to? ie. Lungs check, BMI, etc?
- Dec 2007
- 7
March 30th, 2011 08:34 PM #19* sir boybi regarding sa red (stop) kita ko naman but for the GO signal (green light) white lang po nakikita ko, actually po nag-research na ako about color blindness madami din cases but mine is common red and green color blindness, i can see other shade's of color red, blue, yellow and other primary and secondary colors but if you search on the net regarding color blindness test you will see the difference po, here is the test po! http://www.toledo-bend.com/colorblind/Ishihara.asp
- Dec 2007
- 7
March 30th, 2011 08:42 PM #20thank you sir renzo_d10 hindi naman ako nagkakamali and never had a traffic violation like beating the red light, nakikita ko naman ang yellow(warning) and red(stop) but for the green light (go) i can see only white color/light not much of a problem pero pag distinguish ng other colors medyo hirap na ako kung what specific color yun tinitignan ko, btw inborn po ito sa akin
to ts sorry po medyo OT
high idle RPM at engine start
