Results 21 to 30 of 32
November 9th, 2006 09:18 AM #21
November 9th, 2006 09:26 AM #22
November 9th, 2006 12:59 PM #23
Baka mga girls na walang alam sa sasakyan ang target ng product na ito.
Btw, yung kumpare ko, bilib na bilib sa X1-R na iyan.
November 9th, 2006 01:05 PM #24
November 9th, 2006 06:04 PM #25
- Dec 2006
- 11
October 16th, 2007 11:11 AM #29I don't mind this guy...
I don't believe on his P3,500 per month fuel saving.
I used X1-R for the past 4 years now. What I believe is that it protects my engine and keeps engine performance in top-shape.
I actually witnessed the demo on a friction test machine. The ordinary oil halts the machine at around 50 lbs. of weight. With X1-R it just continued to spin and even without oil too at about 170 lbs or more.
I tried X1-R for about 1,000 kms before paying it. The engine's response changed. Lalo gumaganda yung takbo kahit umiinit yung makina. I challenge you to try it!...but take caution! using X1-R without proper analysis will destroy your engine!
-The best approach to using X1-R is the time that you're near to your oil change schedule.
-X1-R will clean-out dirt and carbon deposits inside your engine coz it will try to stick directly to the metal. Example is the cylinder wall of the engine.
-once the cleaning process is on effect it will produce sludge in the oil (especially for old and dirty engines). Warning!!! this might clog the oil filter and will prevent oil flow inside the engine and failure of course!
-you need to have an oil tester like that of "Fluid Rx", it is an oil drop test to determine if your oil is due for a change or not.
-First 5,000kms: change oil and oil filter put a full bottle of X1-R
-after the first 5,000kms use only 1/2 bottle of X1-R and on succeeding oil change interval schedules.
- this time you will be enjoying the benefits of using X1-R and much more for newer engines!
btw, X1-R is not an 'additive' it is a metal-to-metal treatment. Calling it as additive is ok too coz you 'add' it to the oil
...try to read also about Xado www.xadoshop.com
cheers!
99starexTCI jumbo
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
