Inquiry: where can i find the motor and serial number of a mini?
Pierre, the engine number is located at the engine block below the #1 spark plug while the chasis is either on the bulk head or firewall or at the upper part of the front apron.
carlos
Bro Carlos, esarc, & jemay;
A big THANKS for the info. We've been trying like crazy to look for it but in vain.
Pierre
iba pa po ba ang VIN number sa chassis number ng MINI?
yung nasa bulkhead daw po ang VIN number, e yung body serial number po kaya san specific makikita?
TIA
pahabol po..
pano po ba malalaman kung anong specific model at year model ang mini?may markings po ba na makikita sa oto?
sensya na daming tanong bagito po sa ganito ka cute na oto![]()
jdm, pag may brake servo mini mo, it's 1989 up. eto din yung naka 3 pt rear belts. VIN nos can be found sa bulkhead at sa plate aside from VIN andun ang paint code and interior trim color, yung mahaba sa front apron yun ang commission no., it usually starts with B20S---....
jdm,
yes yung ngang servo ang hydrovac, between them and the fender wall is the washer tank in between. VIN is the same with the chassis # and should be the same sa plate ( usually square ) at yung naka ukit sa canal ng scuttle panel ( panel between the windshield at bago hood. approx located below the wiper or katapat ng servo). Pag yan ay shaved, may sunog ng acetylene or burado, chances are stolen ang mini or ni reshell na yung body.
U r always welcome
Sir Wanker,
great help..nakita ko na po yung body numbers..
thanks a lot
Isang source ng pagidentify ng mini ay sa V I N (vehicle Identification Number). For example ang VIN ay SAXXNNAYCBD - SAX is the world make identifier, for UK and Rover group ,XN is the model code for mini 1300 range, N is the Class, always N on a Cooper, A is for 2-door saloon, the 8th letter identifies engine type, either M(carburetor cars) or Y(fuel inj cars). In the example, Y meaning fuel injection car. 9th letter,C means RHD fuel injection car with 3.21:1 final drive ratio. the 10th, indicates model change, The letter A is found on the Commemorative cars(the part list defines A as indicating 'special edition'), all others should be B. In this case ,its B. The 11 letter is the assembly plant. always D for Longbridge. SOURCE: Original Mini Cooper and Cooper S (The Restorer's Guide) by John Parnell
Pasensiya na mahaba ung pinagbasahan ko eh. Anyway, I believe this will help you in identifying your beloved Mini. Enjoy your ride!
