Results 1 to 10 of 14
June 19th, 2006 12:12 AM #2
Pierre, the engine number is located at the engine block below the #1 spark plug while the chasis is either on the bulk head or firewall or at the upper part of the front apron.
carlos
- Mar 2006
- 114
June 19th, 2006 05:48 PM #4
Bro Carlos, esarc, & jemay;
A big THANKS for the info. We've been trying like crazy to look for it but in vain.
Pierre
- Sep 2005
- 17
September 16th, 2006 12:09 PM #5iba pa po ba ang VIN number sa chassis number ng MINI?
yung nasa bulkhead daw po ang VIN number, e yung body serial number po kaya san specific makikita?
TIA
- Sep 2005
- 17
September 16th, 2006 12:19 PM #6pahabol po..
pano po ba malalaman kung anong specific model at year model ang mini?may markings po ba na makikita sa oto?
sensya na daming tanong bagito po sa ganito ka cute na oto
- Sep 2006
- 53
September 16th, 2006 08:49 PM #7jdm, pag may brake servo mini mo, it's 1989 up. eto din yung naka 3 pt rear belts. VIN nos can be found sa bulkhead at sa plate aside from VIN andun ang paint code and interior trim color, yung mahaba sa front apron yun ang commission no., it usually starts with B20S---....
- Sep 2005
- 17
September 17th, 2006 10:53 PM #8
- Sep 2006
- 53
September 18th, 2006 05:45 PM #9jdm,
yes yung ngang servo ang hydrovac, between them and the fender wall is the washer tank in between. VIN is the same with the chassis # and should be the same sa plate ( usually square ) at yung naka ukit sa canal ng scuttle panel ( panel between the windshield at bago hood. approx located below the wiper or katapat ng servo). Pag yan ay shaved, may sunog ng acetylene or burado, chances are stolen ang mini or ni reshell na yung body.
U r always welcome
- Sep 2005
- 17
September 19th, 2006 09:52 AM #10Sir Wanker,
great help..nakita ko na po yung body numbers..
thanks a lot
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
