Results 11 to 20 of 22
March 21st, 2006 08:02 PM #11
Did you find the problem part already??
I also own a W210.
I think it is the blower regulator. This usually breaks down on most W210 owners. Mine already broke down.
If you only had the PUSH BUTTON controls for the aircon then we can easily see what the problem is since that control has a built in COMPUTER DIAGNOSIS that shows the fault codes.
please bring your car to R&R motors. Look for Nemecio. If you haven't heard of them, they service MB aircons with a computerized system using a LAUNCH OBDII computer to find error codes and erase them. You can easily see what component is broken than through trial in error. BTW, this shop charges reasonable. They have the cheapest computer diagnosis charge anywhere.
They are located along EDSA. Coming from Q.C., go right side POEA ortigas edsa, you will see the shop on the right just across Galleria. Just a little after the Burger machine stall.
Don't even think of going to European motors or even CATS!! for sure, mahal doon ang labor.
Tsikot Member Rank 3
- Oct 2003
- 699
March 21st, 2006 08:07 PM #12Originally Posted by theveed
*rmt6668, sorry wala akong maidadagdag na helpful info except ingat lang sa pagbutingting diyan sa benz mo. dami niyang computer stuff na magkaka-konekta baka kung anong mahugot mo. nung nagka-problema ang sa kakilala ko, we even called MB sa germany and while they were helpful (dami din namin sinubukang tanggaling kung anu-ano) ang kinatapusan e casa pa din ang bagsak namin
March 21st, 2006 08:07 PM #13Originally Posted by rmt6668
March 21st, 2006 08:17 PM #14Originally Posted by smooth
I guess pag binili yung 2002 S-class sa CATS, it would have been covered under warranty or would have been charged way less.
- Mar 2006
- 8
- Oct 2003
- 699
March 23rd, 2006 08:56 AM #16Originally Posted by rmt6668
again sorry i'm not much of any help. just recounting our own experience.
- Oct 2003
- 699
March 23rd, 2006 09:00 AM #17Originally Posted by edl100
- Mar 2006
- 8
March 25th, 2006 03:37 PM #18Thanks for the translation. But I proceeded to test the wirings this is what I found.
I have tested the 3 pin wires using a Multimeter.
(1) Test the middle pin with AC switch disconnected--->0 Volts & plugging the 3 pin wire to the Blower turn ON full blast
(2) Test the middle pin with AC Switch connected ----->12 Volts & plugging the 3 pin wire to the Blower turn ON full blast
(3) Test the middle pin with AC switch connected (a) Switch 1---> 11 Volts (b) Switch 2--->10 Volts (c) Switch 3--->9 Volts (d) Switch 4--->8 Volts (e) Switch 5--->5.5 Volts
(4) With Engine On, test the middle pin with AC switch connected (a) Switch 1---> 12.5 Volts (b) Switch 2--->12 Volts (c) Switch 3--->11 Volts (d) Switch 4--->10 Volts (e) Switch 5--->7 Volts
Whats odd is that the Blower keep blasting away with or without the AC Switch connected or disconnected.
But the Multimeter detected 12 Volts in the middle pin when the AC Swicth is connected but 0 Volts when discoonected?
- Oct 2003
- 699
March 25th, 2006 05:39 PM #19Originally Posted by rmt6668
i would be pleasantly surprised i suppose if you remove the car's battery and the blower is still blasting away. now that's one for the record books.
March 25th, 2006 06:19 PM #20Originally Posted by rmt6668
Anyway, the best person to ask anything about Mercedes Benz is to look for my friend Mr. "SLEEPWALKER" http://www.mercedesforum.com/ Just post "SLEEPWALKER HELP!!" He is the moderator and also the chief service advisor for Mercedes.
BTW, he is a Filipino.
