Page 16 of 28 FirstFirst ... 612131415161718192026 ... LastLast
Results 151 to 160 of 272
    Feb 2010
    #151
    Would you guys happen to have the PMS list for a Mazda 3? I mean the items to be done per PMS visit?
    Check this. I got from the Mazda EDSA dealership.
    Sep 2006
    #152
    Quote Originally Posted by polar01 View Post
    Thanks sir. I need this.
    Sep 2006
    #153
    Quote Originally Posted by go-to-guy View Post
    I have a 1.5 V but this was given to me I don't know why it says 1.6 since wala naman 1.6. I took this pic back in Dec 2016 (40k PMS) because I complained that "Changed spark plugs" was not performed and they said that it was not needed (hence the angle of the pic). Anyways that's more or less what they do.
    Thanks sir.
    Jan 2016
    #154
    We have a Mazda 2/2016, question with regards to the battery, we just got a test report that the battery should be replaced. Would getting a CTEK CT5 prolong the current battery life?
    Or should I just purchase a new one then use ctek on new battery?
    Current battery reading is:
    VOLTS - 12.22V
    MEASURED - 124 CCA
    RATING - 355 CCA
    TIA
    Scrap my question, wala pala kameng istop. LOL!!!
    Dec 2017
    #155
    Quote Originally Posted by lipstick0001 View Post
    VOLTS - 12.22V
    MEASURED - 124 CCA
    RATING - 355 CCA
    TIA
    For your peace of mind, buy a new one and that CTEK battery charger. On the other hand, if you like to have some sort of "adventure" like me, you can buy a jump-start battery for you to continue using your old battery.
    In a way, you are "extending" the life of your old battery. In other words, you'll be delaying the inevitable of buying a new battery. In case the battery died, you use your jump-start battery to start your engine. Your next stop is a battery shop.
    Jan 2018
    #156
    Personally, I would just replace it with a new battery.
    Unless you are maintaining multiple batteries or have a car that just sits in your garage for weeks and months, I find it hard to justify the price of a battery tender. I would just keep my battery and replace it once it's dead.
    Dec 2017
    #157
    Quote Originally Posted by SpinCycle View Post
    I believe that you can justify the cost of a battery tender once you have extended the life of your battery for a year or two.
    In my case, my battery cost about 20k. I don't have plans to replace it next year so I am using CTEK battery charger. Plus, I always bring a jump-start battery.
    Jan 2018
    #158
    If the cost of the battery is more than twice of the battery tender, it makes sense. You'll get your ROI much quicker.
    #159
    From experience, a good tender does extend regular batt life around a coupla years. CTEK is worth getting.[emoji106]
    Mar 2018
    #160
    Spark plugs and ATF fluid panay "inspect" lang up to 60K. Surprisingly low maintenance.
MAZDA Cost of Maintenance/Ownership after YOJIN 3
