Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Dec 2010
    Hi Sirs,
    By car what are best way from monumento to mckinley (fort), and vice versa?
    I will be driving my first car, kinda nervous Thanks!
    Oct 2008
    Take EDSA, probably not the best but the shortest and easiest. Just go westward from Monumento straight to EDSA-Ayala intersection then turn left at Ayala Ave.
    Good luck
    Dec 2010
    Quote Originally Posted by SecretShop View Post
    Good luck
    Thanks a lot!
    Dec 2010
    Sirs,
    Plan kong mag-left turn sa Ortigas from Edsa then C5 to Mckinley, pero mukhang maraming possible routes in-between. Baka may suggestion kayong route.
    Monumento -> Edsa -> turn left sa ortigas -> Please insert suggestion -> C5 -> Petron station -> mckinley
    Thanks in advance!
    Oct 2008
    Quote Originally Posted by lego View Post
    Sirs,
    Thanks in advance!
    Bossing, baka matrapik sa ortigas.
    May route din ako ganyan, usually what i would do i avoid edsa, especially along the cubao area.
    Route ko is,
    Take EDSA till Quezon Ave and make a left turn going to Quezon City circle.
    Take the exit going to Philcoa, going towards UP.
    Take right turn on CP Garcia. Go all the way to Katipunan.
    Take right turn, then straight. Wala na turns dito as katipunan exits into C5.
    Granted it is a long way around. Pero 80% of the time, i don't encounter traffic as bad as in edsa, and time spent ko is shorter.
    I have in-laws at monumento area in caloocan, in fairview, in SJDM in bulacan. I live in BF Paranaque, and go to those areas around 2x a month and thats the route i take. So im speaking from experience na din.
    Hope to help
    Dec 2010
    Quote Originally Posted by Zhandros View Post
    Route ko is,
    Hope to help
    Thanks a lot. subukan ko yan
    Hi Sirs,
    Let me guess? Is this for the Ford Club EB?
    Jun 2006
    remember to take the undertunnel along katips, that is the link to C5. It's after the flyover, then an overpass. When you see the MMDA over-U-turns, shift to the right and enter Market Market, go straight and when you see McDo to your left, take that left (5th Avenue). Actually, I go through another street, (first stoplight) but it's a bit complicated for a first timer.
    Personally, this is what we do (we fly at least twice a month and we live near NLEX).
    Since you're driving your first car (i hope you've had a lot of driving time with another car), that route is good. There are no buses that will bully you around, just trucks.
    Don't be nervous, as long as you don't hit and run over someone, you'll be fine. Are you gonna drive an automatic? If you're driving a manual, practice your hanging skills. Once you get the hang (pun not intended ) of it, you'll be ok.
    Dec 2010
    no, it's home to work route
    Dec 2010
    Quote Originally Posted by Horsepower View Post
    Thanks for the detailed tips! Btw, i'm driving manual, so far nasurvived naman ako sa edsa-ayala route. Nakakapag hang-on naman ako, using e-brake , pero medyo kabado pa rin esp sa uphill traffic, konting incline lang e-brake agad
    In my way home (northbound), may kasabay ako, then ibababa ko sya sa may ortigas area, so balak ko,
    C5 then go down sa pasig boulevard,
    diretso sa capt Javier
    meralco avenue then labas na sa ortigas.
    OK ba to? (based lang ako sa google maps)
Route from Monumento(caloocan) TO Mckinley (taguig)
