Results 1 to 10 of 21
July 11th, 2018 09:01 PM #1
A quick repair from the Dunlop Center(not in m. manila)
Nail head was severed off, sharp end was left and it was in the middle tread. 20psi this morning. At first the guy was saying no bubbles including the tyre valve. So I told him to increase the tyre pressure. Lo and behold really small bubbles were super slowly forming.
1. scuff surface and clean off inside aka prep surface
2. tyre glue, and let it dry
3. set patch
4. roller out air
- Jan 2008
- 4,726
July 11th, 2018 11:47 PM #2Hmmm.. medyo newbie yung repair guy nila.. SOP dapat na increase tire pressure to check for leaks
July 12th, 2018 12:50 AM #3
July 12th, 2018 07:50 AM #4
hhmm if im losing 2-3 psi monthly, may leak na kaya yun na ganyan kaliit?
kaso halos lahat ng gulong ko ganun eh O_o
July 12th, 2018 09:18 AM #5
wala yan bro normal yang ganyan kapag on a monthly basis lahat sila pamtay magbawas.
ang hint sa ganyan para malaman mo kung alin yung may maliit na leak is kung alin yung may pinaka malaki usually 4psi and up difference ang bawas sa hangin once nag refill ka
July 12th, 2018 09:25 AM #6
July 12th, 2018 09:34 AM #7
pwede na rin palitan yung pito mo if you want given that reason or kasabay ng pagpalit ng gulong.
try mo kaya muna lagi dumiretso sa air pumps ng gas station everytime after mo magpa gas up? makakakuha ka ng baseline kung may leak nga
July 12th, 2018 10:01 AM #8
- Jan 2008
- 4,726
July 12th, 2018 10:07 AM #9Make sure to change tire valves at least every 3 years or when you change to new tires..
- May 2018
- 611
July 12th, 2018 02:19 PM #10
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
