Results 1 to 10 of 57
September 3rd, 2018 02:46 PM #1
Good practice ba na ilipat yung dalwa na nasa harap sa likod and vise versa for a certain number of months or year?
- Sep 2016
- 2,348
September 3rd, 2018 02:49 PM #2Yes sir. There are several patterns on rotating tires. Click link for sample. tire rotation patterns
September 3rd, 2018 02:52 PM #3
Depends on the type of tires you are using. And yes its good to rotate the tires every few thousand kilometers to prolong its life..
September 3rd, 2018 07:16 PM #4
Ako, every 5,000 kms, or pag PMS. Kung pare pareho wheels & tires mo, including the spare, go for a five tire rotation pattern. With regular tire rotation, you can minimize abnormal tire wear & maximize tire life. Also invest in a good tire pressure guage & always have your nuts torqued. Usually, over tightened yung nuts at pwedeng maputol kung sobrang higpit.
September 3rd, 2018 09:36 PM #5
Actually, sa tagal ng driving life ko, ay wala pa akong na encounter na shop na gumamit ng torque wrench sa gulong ko, maybe sa casa, dahil di ko nakikita, pero servitek, bridgestone, yokohama and even the famous Rapide, wala ni isang gumamit sa akin nyan.
- Feb 2014
- 2,696
September 3rd, 2018 09:56 PM #6
sa casa gamit impact wrench. sometimes they use torque wrench like ford. i even asked what setting he used. 90 lbf-ft daw. the manual recommends 100. that's good enough
sa tire shops, walang gumagamit ng torque wrench. tira lang ng tira. that's why broken studs are quite commonso when i have a flat i personally install the spare then put the flat in the trunk. then i install the patched tire myself
September 3rd, 2018 09:59 PM #7
- Feb 2014
- 2,696
September 3rd, 2018 10:15 PM #8
- Sep 2005
- 392
September 4th, 2018 04:10 PM #9I do five tire rotation.... Spare included. It's great to have all same mags including the spare...
I do it every 6 months.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
