Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 87
    Jan 2016
    #31
    Quote Originally Posted by DannyJr View Post
    As always, meron sa OLX. I cannot vouch for the quality or authenticity of the product, or the seller. Caveat emptor!
    Pareho lang kaya sila nito?
    Portable 12V Mini Metal Auto Car Air Pump Compressor Tire
    InflatorGauge 12 - Intl | Lazada PH
    Yan o ito ang pinag-iisipan kong bilhin..
    CYCLONE Heavy Duty Air Compressor With Working Light (Yellow) | Lazada PH
    Sep 2016
    #32
    Yung unang link, katulad sya nong sa ACE Hardware na ELEVO Brand, 1800..
    Jan 2016
    #33
    Malamang yan na kunin ko, free delivery naman at may rebate pa sa shopback, plus may bonus pa na return buyer discount hehe..
    #34
    Elevo EVO688 less plastics, large compressor.
    After 4yrs of use sa 4 vehicles(and sometimes used to prime fuel filters) camshaft lock broke loose causing the cam to misalign. Na stuck up yung piston pero hindi nasunog ang motor.ang galing.
    Cleaned and rebuilt, applied lock-tite on those screws holding the cam to the motor shaft and the cylinder.
    Solid ang construction neto- zinc body, piston ring made of teflon material, and the sleeve/liner of the bore is well machined.
    Apr 2010
    #35
    oil-less ba yung ganyan? have the same model for more than a year now, ok pa rin
    #36
    Yes oil-less, but I have to apply thin film of oil on the sleeves during rebuilding. Siguro para tumagal kelangan din linisin yung sa bearing area dun na accumulate yung dumi. Cleaned using brake cleaner and re-sealed top/bottom rubber gasket with silicon paste.
    Nilagyan ko din pala ng polyurea grease yung bearing sa tabi lang to replenish the washed grease, naka press kasi sa cam.
    saw one yesterday all metal... 160psi 35l/min for around 2500pesos. and a slightly bigger one for 5000(didnt check the psi rating tsk) alligator clamps only lol.
    Apr 2018
    #38
    My best brand is EPAuto as it is fast and plugs into the cigarette lighter
    Apr 2010
    #39
    After countless 0-35 PSIs on our vehicles and helping other motorists eh bigla na lang tumigil yung compressor. Ginagamit para makatakbo lang sa vulcanizing or totally walang laman ang reserve tire.
    Wala namang sira physically on the outside or amoy sunog
    Where can I have this repaired (anong shop ba dapat puntahan ko, electronics ba or machine shop or what)
    edit: tried PM-ing you pero puno na inbox mo
    Apr 2010
    #40
    ^can't edit my post anymore
    fuse lang pala nung power socket ang culprit. noticed my phone wasn't charging and nung binunot ko ang fuse eh open circuit na pala.
    wala na yung manual pero IIRC the compressor exceeds the 10A limit for the socket. dunno bakit ngayon lang nangyari yun after years of operation, might modify with alligator clips na lang direct to batt
Tire Inflator/Air Compressor
