Results 1 to 10 of 15
- Apr 2018
- 46
June 9th, 2018 12:52 AM #1hello mga ka-tsikot, just got an OEM fiesta mags for my ecosport pero hindi pala sukat so i have it re-stud from 100pcd to 108pcd, any expert input is highly appreciated, TIA!
June 9th, 2018 04:10 AM #2
- Apr 2018
- 46
June 9th, 2018 04:44 AM #3
June 9th, 2018 05:39 AM #4
June 9th, 2018 08:30 AM #6
- 54,258
June 9th, 2018 09:33 AM #7
June 9th, 2018 09:54 AM #8
The aesthetic value of your car is not worth compromising your safety or the safety of the other motorists. Use the correct bolt pattern. As a matter of fact, use only JIS, CSA or US DOT standard wheels. If you can, use the same offset and same width to maintain the same scrub radius. Negative offsets shortens the life of the bearings or outer bearings and shortens the service life of the steering components in addition to a less stable vehicle handling.
June 9th, 2018 12:44 PM #9
I agree with the posts above. It's NOT safe...
But I've seen/done/used ones before...
So I guess it all depends on your budget and luck.
***I've tried punching new holes to the wheels... And changing the holes of the car. Student pa ako noon, have to play with the budget I have.
- Jan 2008
- 4,726
June 9th, 2018 01:17 PM #10Id rather stick to my oem wheels.. kung kulang budget tyaga muna mag ipon to buy the proper set.. ok lang sana kung yung pina modify nya eh wheels na may aesthetic or sentimental value.. kaso oem lang din from another model.. minsan sa pagtitipid eh mas malaki pa magagastos dyan
Nope Prius had variable speed/inverter Acs since its 2nd generation(~2004)....
A/c
