Results 1 to 7 of 7
- Mar 2009
- 9
May 23rd, 2009 08:53 AM #1guys,what is the recommended psi for a 215/40 r17 tyres to survive in edsa? ty
May 23rd, 2009 02:36 PM #2
Are your tires mounted on a Jazz? There's a sticker on the driver's doorjamb for that. On my GD1 Jazz the recommended pressure was 32F/30R.
May 24th, 2009 03:13 AM #3
If it is original that come's w/ your car it listed in your door jam.
If not...see the tires recommended on the side wall of the tire.
May 24th, 2009 06:32 AM #4
v6
the tire pressure listed on the door jamb sticker( on the fuel filler lid for europen cars, on some asian cars in the glove box compartment and in the owner's manual) are for original tire specs for speed, load, and tire size. if the tire is now equipped with a lower profile tire size, this pressure specs does not apply since the tire is stiffer than the original size and load rating tire. it would have a very stiff ride and reduced road/tire contact. of course the friction surface between the road and the tire will greatly be reduced making it unsafe for stopping. the pressure has to be reduced than as if the car had original tire size. check the tire manufacturer's recommendation for the specific car. and oh, DO NOT, i say again, DO NOT use the tire pressure on the sidewall of the tire. that pressure is the maximum inflation pressure for the tire and not necessarily the pressure recommended for the particular car. if you have doubts about the tire pressure specs, please do not guess. the only contact between your car and the road is about the area of a dinner plate for four of your tires assuming you are using the right tire and using the right pressure. let's play it safe. you can google this recommended tire pressure.
jick
a.s.e. certified master automobile technician
a.s.e. certified master heavy duty truck technician
international automobile technicians' network
May 25th, 2009 04:20 AM #5
- Apr 2008
- 27
May 25th, 2009 06:30 PM #6for me safe pressure is to look at the maximum psi on the sidewall then minus 10%.
ex. sidewall maximum is 40psi minus 10% is 36 psi. the start playing from 36 psi. i think 34 to 35 psi is good
- Apr 2009
- 1,902
May 21st, 2010 02:23 PM #7Good thing I found an existing thread for my query.
What could possibly be the ideal tire pressure for the ride?
I'm concerned since both have 17s.
215/45R17 (Westlake tires) on Sentra GX
Current psi: 32F/31R
215/40R17 (Advan Neova AD07) on Astina
Current psi: 31F/31R
I checked the tire pressure recommendations on their door walls but the ratings for the largest rim diameter they gave were for 15s wheels only.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
