Page 1 of 5 12345 LastLast
Results 1 to 20 of 87
    Sep 2016
    Hi Sir/Madam, appreciate your suggestions about portable tire inflator/air compressor. Anong brand ang mga trusted at saang dealer pwedeng bumili? TIA
    Aug 2012
    Gamit ko Windek Automatic, Digital Tire Inflator. Very easy to use. You can set the pressure you want into memory. Backlit LCD display. With White and Red LED flash light for night use or emergencies. With 2 adaptors for inflating other things.
    Sent from my D5833 using Tapatalk
    im using coido digital compressor, meron pa syang setting na ilalagay mo yung desired pressure then mag cut off, kaya lang ngayon hindi na gumagana yung feature na yun but everything else is working, bumili na lang ako ng tire gauge
    May 2009
    ts, go for the metal pump....wag ka bumili ng plastic.
    search ka sa lazada meron just under P1.5k lang....yung "total" na brand seems good enough....been also planning to buy one for long trips or emergencies.
    may air compressor ako kaso malaki....hehe
    Meron palang plastic na pumps hehehe
    Jul 2013
    We have a thread about this just recently. I just can't find it through the search function.
    Elevo EVO688 less plastics, large compressor.
    Feb 2016
    Sa SUV pwede ba ang portable na compressor? Ung sinasaksak lang sa 12V
    Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
    Aug 2012
    Quote Originally Posted by markkevin View Post
    Pwede. No problem with mine.
    Lahat naman kaya 32psi(most vehicles) Kahit lagyan mo ng 40psi matagtag naman. Kaya padin. I think max is around 45-50psi. Di na kaya mga 90-115psi for trucks hehehe
    Feb 2011
    Pwede yan boss. Already tried those small inflators that you can purchase from Blade on a 255/45R20 tire, and it works.
    Sep 2016
    I would suggest getting a metal tire compressors. Mas heavy-duty ang parts kaysa sa flimsy plastic box type of compressors. Basically plastic tube lang ang compressor nya sa loob. Tingnan nyo mechanism nyan sa video:
    You don't need to get the exact brand endorsed sa video. As long as you get a metal compressor, ok na yan.
    i have the metal one above. more expensive, but it has lasted longer than the cheaper plastic-bodied black ones.
    they also inflate faster.
    Aug 2012
    I have 2 plastic type inflators. One is 4 years old. One is more than 1 year old. Parehong working pa rin. Depende sa product quality yan.
    May 2009
    pero the metal piston-cylinder assembly last longer......
    tsaka syempre depende rin sa frequency of use.
    May 2009
    pwede naman pero kung sa akin din lang e papalitan ko yun ng alligator clamps at irekta na lang sa battery.
    those pumps (e.motors) draw about 10 amperes and your typical cigarette lighter outlet is rated at 15 amperes. tapos for 10 minutes na nagpupump kamo. ambilis uminit ang wiring nyan.
    Aug 2012
    Ako naman rekta sa AC power. 220V AC to 12V DC adaptor gamit ko.
    Sep 2016
    Quote Originally Posted by red_one View Post
    Thanks Sir sa reply
    Sep 2016
    Quote Originally Posted by seymorebutts View Post
    Sir, diniscourage kami nong salesman sa ACE Hardware, wag daw coido, sumasabog daw. Not sure kung totoo, baka over use lang hehe
    Sep 2016
    Yan sir nericommend sakin ng salesman sa ACE Hardware
Tire Inflator/Air Compressor
