Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 110
    #41
    Quote Originally Posted by ogieboy042 View Post
    Help naman po newbie
    Upgrading mags/Wheels Mitsubishi adventure 185/65r14 to 245/45r17 nabili ko lng ng 2nd hand mags kailangan rin palitan Tires anu po Pro and Cons any advice po?
    I think the tires are 9% bigger than the stock tires. Maximum allowable is 3%. A good resource site you may want to look at is wheel-size.com
    Jun 2016
    #42
    Quote Originally Posted by jettp0gi View Post
    Sobrang bigat na nyan sir compared to stock. Mas mahirap na i-accelerate at i-preno yan. Mas matagtag na din ng di hamak. At least put good quality tires na lang to compensate up to some point. But then, mas mahal ang na din in general ang tires para dyan so dagdag disadvantage din. Wala nang advantage, except siguro for the looks (which is still subjective).
    ano po suggestion/recommendation palitan ko tires? luma narin ung tire stock sa mags 245/45r17, anu po maganda tires po 225/45r17 or 235/45r17 or 215/55r17 mag fit ba ito mags nabili ko
    thanks po
    Jun 2016
    #43
    c38270cb033c9f0723fe00f4396dc82d.jpg similar/same nyan mags nabili ko anu pwde tires dyn
    7.5J 45 offset
    #44
    7.5J 45 offset
    Sir 205/40R17 ang minimum safe size sa 17x7.5 and closest size sa stock tires mo.
    Pero kung gusto mo talaga yung mga sizes na nabanggit mo sir, double check mo muna kung papasok nga ba talaga. Trial fit ka sir tapos silipin mo sa ilalim kung may tatamaan sa suspension lalo na pag lumiliko at kung sasayad ba sa fender pag nalubak. Or, dalhin mo na lang sa nearby tire shop and ask them. If all is good, have your speedometer calibrated after mounting your new wheels.
    Jun 2016
    #45
    thanks po advice noted po :D
    have your speedometer calibrated? pano po to gawin? mekanico ba? or sa tire shop na?
    #46
    Once pa lang ako nagpa-calibrate sir. Sa casa ko dinala noon. Not sure if other shops can do it.
    Sent from my D6503 using Tapatalk
    Jun 2016
    #47
    how much nmn po inaabot bayad sa casa, ? for sure mahal sa casa
    #48
    Somewhere between P2000-3000 sir. And that was about 8 years ago.
    Edit: I had to leave the car for 2 weeks or so.
    Jul 2016
    #49
    Question mga boss sorry hindi kasi ko famillar sa mga specs ng mga mags and tires e... ano po bang maganda for Honda City GM6 and anong shop po recommended nyo? TIA!
    (First post ko po to) hehe
    Jul 2015
    #50
    Quote Originally Posted by binoperez View Post
    Whats the size of the stock wheels? Compute natin close to stock diameter.
    #51
    i always ask whoever wants to change wheels/tires...
    why? what do you want to achieve? what's wrong with the ones you have now?
    #52
    If it's the E variant like mine, stock tires are a bit ugly (at least for me), specially the M/T variant wheels (steelies, heavy). Vx wheels look slick, but are too heavy for a 16" (9.2kg).
    For 17" wheels:
    - 17x7, 45mm-55mm offset (Vx mugen wheels have 55mm offset)
    - 17x6.5, 45mm-55mm offset
    You can put 205/45r17 tires on any of the above.
    You can also go as low as 42mm offset but I would't recommend it. Disclaimer lang din sir, matagtag ang 17".
    For 16" wheels:
    - 16x6.5, 42mm-55mm offset, use 185/55r16 tires
    - 16x6, 42mm-55mm offset, use 185/55r16 tires (Vx wheels have 53mm offset)
    You can also use 205/50r16 tires on any of the above but use 45mm+ offset.
    For 15" wheels, I doubt gusto mo ito sir. Sabihin mo lang if ever hehe.
    Shops, depende sa preference/budget mo sir. Do you want original wheels? Or will replicas do?
    Jul 2016
    #53
    Boss jettp0gi parang kokonte nakikita ko online na mags na 16. Mas madami 15 at 17 for gm6. Baka may alam k store or link na nagtitinda ng mags 15 or 16 na may offset na tulad ng binigay mo. Tia
    Sent from my SM-N920C using Tapatalk
    #54
    Quote Originally Posted by 24blink24 View Post
    Yes sir, medyo rare nga ang mga 16s sa pinas. I got my set of 16s from autoplus. Marami din 16s sa rota sir. Pwede bumili deretso sa planta nila. Meron din sa wimpwheels (honda jazz club sponsor yata ito).
    Jul 2016
    #55
    Curious lang ako. Sa napagtanungan ko na mga mags lahat daw pasok sa honda city gm6 kahit ang offset hindi umabot sa +42. Sir jett ano b offset ng mags mo.
    #56
    48mm ung wheels ko sir. And "pasok" does not always equate to "walang problema". Yung mga specs na binigay ko sir ay yung 100% sure na walang rubbing issues (both sa fender at suspension) kahit pa full ang kotse. Given of course, na you're not lowering your ride. Outside those specs, I do not recommend. Pwede ba malaman sir kung anong specs ng wheels meron sa napagtanungan mo?
    Jul 2016
    #57
    Rays te37 ultra 16x7 4x100 offset 42
    15 x 7jj offset 38
    Madami pang iba. Wala kasi ako sa Pinas sir kaya online lang ako nag iinquire. Misis ko gumagamit ng kotse. Honda city 1.5e mt. One time tumama daw sa bato sa highway sumabog isang gulong. Nawala ang isang hub cap. Pangit tuloy tingnan. 15 and 16 pinag pipilian ko n size
    #58
    15 x 7jj offset 38
    PM'ed you sir regarding sa nahanap mo.
    Jul 2016
    #59
    Sell your old mags on OLX you will get more for them than trading them in
    Jul 2016
    #60
    Good morning!
    I am new to the sitre and my question might sound like a dumb question so please bear with me.
    I have a BEIGE Toyota Altis 2011 (Gen 10.5???) and was wondering what ROTA mags will make the car look good (size, color and any other specs I missed out on). Rota because I am on a tight budget.
    Also, I would like to lower the car, let's say a drop of 1.5. What is a good brand of lowering springs to buy that will not be too costly? And where to purchase it from? I live in QC. From what I gather, lowering springs are cheaper than coil-overs.
    Thank you.
    Abet
Questions about wheels and tires
