Dumaan din ako kanina sa tire shop near our house. Sabi nung bantay nila dun, ok lang daw yun at makapal naman ang mga side wall.
Sent from my LG-D855 using Tsikot Forums mobile app
Not sure if I have a hidden puncture but what are the possible causes if your tire loses about 1 psi per day?
I have this 1 tire that slowly loses around 1 psi per day. A few weeks ago, nabunot ang metal na pito while topping up the air sa gas station. I thought mawawala na ang problema after I had it replaced. Kaso hanggang ngayon nagbabawas pa rin ng hangin. From 35 last Sunday afternoon, 32.5 na lang siya by Wednesday night.
Ano ba ang dapat kong ipa-check aside from punctures? Nagli-leak din ba ang hangin sa edge na in contact with the rims? Made-detect ba sa mga roadside vulcanizing shops ang mga ganitong leak?
Aside from the spare, all my tires are 4 years old. The tire in question is currently on the rear passenger side.
Kung walang puncture at hindi pa more than 8 years ang gulong, the tire bead seating on the rimmight have some dirt or obstruction kaya may sumisingaw. Have it (rim) checked and cleaned and put some water or water with soap before re-installing the tires.
Pito also sometime need na palitan. Inflate sa max tire pressure at usually makikita issue sa rim at sa pito.
yes, the leak can be detected.
the tyreman immerses the wheel in water, and carefully observes for minute air bubbles, coming from the tyre, or the edge of the rim.
he also manipulates the pito and looks for air bubbles, to determine if it needs replacement.
it's crude, but it works fine. tiyaga lang.
Turns out to be a puncture after all. Maliit na pako.
Sent from my 3210 using Tsikot Forums mobile app
Sa MTB naman yung wires ng gulong from bald truck tires and mahirap makita. Mas manipis pa sa stapler wire yun kaya dahan-dahan talaga air loss. Buti sa tires ng kotse hindi na kaya ng stapler wires or the likes, mga guntacker na bala at pako na maliliit na lang kaya. Ewan lang thumbtacks hehe.
