Page 51 of 71 FirstFirst ... 4147484950515253545561 ... LastLast
Results 1,001 to 1,020 of 2415
    Jan 2018
    Don’t get Achilles ATRs. Mine had bulges in the inner side wall after 18 months.
    Quote Originally Posted by SpinCycle View Post
    bulges are from wrong tire inflation.. i could be wrong..
    is it the tire, or is it the over-inflating user?
    The Achilles ATR Sport is a bad tire model. If you need Achilles tires for daily driving, get the 2233. This is roughly the same level as the Neuton NT5000 and Accelera Phi.
    If you need very grippy tires (grippier than Bridgestone Potenzas or Yokohama Advans), get the Achilles 123S. Outstanding track tire although it wears out very easily.
    I used Accelera Alpha on the Fiesta. Oks naman, better than the Hankook Optimo which came stock on the car.
    Jan 2018
    I kept my tires at a constant 32 psi checked each week. My other tires have never bulged the same way the ATRs did.
    all four tires?
    that's bad.... for the brand.
    Jan 2018
    all four tires?
    2 of them lang. But I decided to replace all 4 since I lost confidence in them all together.
    32 for low profiles... thats asking for "it"
    Jan 2018
    I’ve had other low profiles that were set to 32. None of them had the same issue
    I use 32 for ALL the 18" tires I've ever used. No lumps whatsoever.
    The ATR Sport is an awful tire and there's a lot of negative feedback on it - poor grip, poor durability, poor build quality. Which is why Achilles released the ATR Sport 2 soon after, because the ATR Sport was such a dud.
    Even Mang Ben, owner of Ben's OK, adviced me to go for the cheaper 2233 even if he'd make more money with the more expensive ATR Sport because he's gotten bad feedback about it from customers.
    Just because it hasnt happened.. doesnt mean it wont.
    Honda suggests 35F33R for the CTR and on the Civic Sport 235/40/18s
    Should we follow Honda?
    Factory tire pressure recommendations factor in fuel efficiency besides load.
    There are good & bad tires.
    Jun 2012
    May mga bulok na tires talaga like nexen sa starex. 15k km pa lang, ang kapal pa, may bukol na. At kung magbabasa basa ka, prone talaga sa bukol ang nexen kahit sa ibang cars. So just accept it. Hindi sa usage yan
    ganyan talaga ang nexen. makapal pa bumububukol talaga. im sure maingat yun driver at non existent ang gutter. bulok ang nexen 🙃
    Check here Tyre reviews, tests and ratings - Tyre Reviews
    Sep 2010
    Quote Originally Posted by istan View Post
    You may also consider looking into this.
    Top 5 Tire Brands to AVOID Purchasing in 218 - CAR FROM JAPAN
    thanks....
    Jan 2019
    Quote Originally Posted by rj_tim View Post
    Any suggestions? And price. Thanks!
    Toyo Tires ok naman po yung saka matibay mura pa po.
    Jan 2019
    Thank you po. Ganun na lang nga gagawin ko, or kung saan abutin ng 1000KM na may Hyundai na casa ipa PMS. Isa na lang sir, ayos lang po na travel ang ganun kahit bagong kuha pa kotse? May narinig lang po kasi ako dati na pag bago need pa i break in? Salamat po.
    Sent from my SM-J730G using Tapatalk
    Apr 2008
    Quote Originally Posted by nikkol View Post
    Well, you do need to use the car for it to "break in". [emoji16] Your owner's manual will have detailed instructions on the limitations of driving under break in period. But generally, as long as you don't flog it to its limits too much, you will be fine.
Low budget yet good quality tires
