Results 2,391 to 2,394 of 2394
February 2nd, 2024 10:34 AM #2391
If you can claim for warranty, do so. It's not normal to have a bulge on the sidewall... however slight.
The longer you wait, the more reason for the seller to dismiss it as user error. Besides, it's also unsafe and not road-worthy.
My Arivo ARZ1 is coming up to 1 year of use this month. So far (knock-on-wood), it hasn't received any punctures nor did I find any obvious defects. All tires are doing reasonably well holding pressure.
My last air fill-up was a few days before we went to Baguio for our Christmas vacation (34 PSI, cold). Today, it's down to 32-33 PSI, cold. So I went from losing 1 PSI every week or so on the old stock Yoko tires, to just around 1 PSI every month with the Arivos.... which is normal. I should mention that switching to solid valve stems has a lot to do with that.
Anyway, I'll top them off again to 34 PSI and do a more thorough inspection of the tires this weekend.
- 52,734
February 2nd, 2024 10:52 AM #2392i agree with oj.
i feel brand new tyres should look and feel "perfect" upon proper installation. complain and replace if you can, as it is under warranty.
but as yours appears to have been purchased online...
if you can feel the imperfection by hand, and it is slightly visible,
it may become more prominent in the near future.
let us just hope it won't be a dramatic manifestation.
sometimes, these manufacture imperfections manifest themselves in the un-align-ableness of the vehicle.
good tyres will not "pull" to one side or make strange sounds or vibrations under all conditions: forward, backward, low pressure, high pressure, low speed, high speed.
hey! potentially dangerous carcass imperfections are not rare.
good luck.
errr,
locally purchased tyres from an authorized dealer usually come with "free" installation.
ask around, po, if the local prices are significantly higher, as to warrant purchasing tyres elsewhere.Last edited by dr. d; February 2nd, 2024 at 11:22 AM.
BANNED BANNED BANNED
- Jan 2024
- 13
March 1st, 2024 02:29 PM #2393na google ko na pero wala, ano pinagkaiba ng deestone sa thunderer? kase sa thunderer naka lagay na gawa din siya ni deestone?
- Nov 2019
- 973
Kung ako.. Age: 2017 = 7 years old = 70k kms Typical PMS schedule: 1 year = 10k kms Ergo 100k...
Ford Everest 2015
