Results 1,561 to 1,570 of 2394
- Nov 2018
- 3
November 6th, 2018 06:26 PM #1562
November 6th, 2018 07:28 PM #1563
Mayrun Achilles or Gajah Tunggal na SUV tires, mas mura kaysa Bridgestone. Mayrun din Cooper tires.
- Jan 2011
- 300
November 7th, 2018 08:46 AM #1565
- May 2015
- 146
November 7th, 2018 10:30 AM #1566
- Nov 2018
- 3
November 7th, 2018 08:33 PM #1567Recently bought a pair of GT Champiro sx2 for my Galant GTI
After mounting went up to Tagaytay, and I can say these tires really has grips, despite going up with a wet road surface
The prices range from 5000-5500 depending on the tire size
Hope this helps!
November 8th, 2018 11:49 AM #1568
Anyone with experience with LT (light truck) tires ie. Canter
size: 7.50 R15 12PR
OEM (and currently installed) is Bridgestone R200 but trying to find more affordable alternatives.
Tried GT (Gajjah Tunggal) before and very bad experience. So definitely no going back to that.
Considering Casumina (frm Vietnam)? Anyone with experience with this?
- Jun 2012
- 4,448
November 8th, 2018 12:22 PM #1569
November 8th, 2018 02:25 PM #1570
You might know this already but I'd only compare radial vs radial tires and bias vs bias tires. If you do a lot of highway you'll find that replacing your OEM Bridgestone radials with bias tires will get you a lot less mileage.
I've had Casumina radials and while he price is good, I've never had one that made it to the tread wear indicator. They all had cracks on the tread after 2 years. And this is a light to moderately loaded truck with relatively low mileage.
high idle RPM at engine start
