Results 2,131 to 2,140 of 2394
January 20th, 2021 10:20 AM #2131
January 28th, 2021 10:47 PM #2132
225/50/R17
Which would you choose/recommend?
PROD DATE 2020:
Dunlop LM 704: 5,700
GT Champiro HPY: 5,500
Yokohama Blueearth ES ES32: 5,500
2nd hand:
Michelin Primacy 3 ST - PROD DATE 2019 80% thread life: 2,500Last edited by xninjax; January 29th, 2021 at 12:41 AM.
- May 2017
- 2,099
January 29th, 2021 06:48 AM #2133
January 29th, 2021 09:13 AM #2134
Yep I havent tried thunderer yet but it should be same as deestone since same company.
January 29th, 2021 09:24 AM #2135
January 29th, 2021 09:34 AM #2136
I check my tires threadwear and it is different bridgestone, deestone, michelin and now petlas. Bridgestone being the lowest at 200 and michelin is the highest at 420 then deestone and petlas falls in between. The higher the threadwear the better?
January 29th, 2021 09:51 AM #2137
January 29th, 2021 09:51 AM #2138
It depends on how you want your tires to perform. If you want tires that last longer, go for the higher thread wear rating. If you want more grip and better performance, go for the lower thread wear rating. Anything below 200 thread wear rating is already something better suited for track purposes.
January 29th, 2021 12:23 PM #2139
Not sure if this was already discussed... for 2015 Innova G Diesel.
Should I go with Yokohama Aspec A300 (OEM) or the Yokohama BluEarth ES32?
The ES32 is P350 cheaper, FWIW.
January 29th, 2021 12:30 PM #2140
there's this youtube article, about a 2000s altis, that had a high rpm on cold start (2000+ daw),...
high idle RPM at engine start
