Results 1 to 10 of 44
February 14th, 2018 06:43 AM #1
Alam ba ng shop na bibilihan mo ng rims and gulong ang match or recommended na sukat sa kotse mo?
February 14th, 2018 07:23 AM #2
Most reputable shops ay alam na ang stock size, bolt pattern at offset ng rims mo just by looking at your vehicle dahil malamang nakapag install na sila sa similar car. Unless gusto mo ng wider diameter or different offset ng rims then I suggest better test fit mo na lang.
- 53,004
February 14th, 2018 08:41 AM #3
February 18th, 2018 02:29 AM #4
Salamat sa Input mga Sir. Actually, diko naman talaga type yung mga malalapad na gulong. same size lang din gusto kase, nabasa ko online na di basta nagpapalit ng rims and wheels kase pwede maapektuhan yung suspension etc.
Nalilito lang kase ako dito sa site na to, Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com - wheel and rims calculator sya, so diko maintindihan hahaha. kaya tinanong ko dito. Kung most likely nman alam nila sa shop then wala nmn siguro magiging problema.
PS. Since mirage hatch kotse ko, ang nakalagay lang sa manual eh yung size ng stock na gulong for both trim models. So diko alam kung yung stock na '15 ng GLS model eh pwede sa GLX which is '14 kase, yung lower trim model eh walang stabilizer bar, so baka matagtag pag manipis na gulong ang ilagay. Pero same width nmn.
Salamat ng marami.
- 53,004
February 18th, 2018 10:31 AM #5that is what the tire calculator is for, po.
input the numbers for the 15 inch, and those for the 14 inch. you will then be able to compare the diameters and circumferences. the closer they are to each other, the closer the odometer and speedometer readings will be to each other, should you choose to replace tires. it will also give you an idea on which tire size will probably not rub against the wheel well and body.
but as since both tire sizes are factory, i expect very minimal differences in diameter and circumference. they should be inter-exchange-able.
the calculator is used to see just how far your choice of aftermarket tire size will be, from the factory spec.
February 19th, 2018 11:47 PM #6
thank you. So napansin ko nga may odo and speed reader sa calculator. Question, how does that affect the odo and speedometer reading? Ibig sabihin din ba, yung factory wheel hindi basta nabibili sa labas pag magpapalit?
Another thing is, sinunod ko lang yung factory spec ng gulong pero bakit makapal yung rubber na lumalabas eh yung 15' ng GLS model eh manipis yung gulong.
Pasensya na first time kase. hehe. pero malaki tulong to, salamatLast edited by Salanguit; February 19th, 2018 at 11:54 PM. Reason: pics
- 53,004
February 20th, 2018 12:05 AM #7if you use a tire with smaller circumference than factory spec, your odometer will give more km traveled than the truth, and your speedometer will give you higher speed than the truth.
most car manufacturers use tires that are commercially available to you and me. if not that brand in particular, at least the tire size and aspect ratio, but different brand.
..."makapal na rubber..."? read on aspect ratio, po. the explanation is long, but the diagrams google will give, make it easier to understand.
March 4th, 2018 11:51 PM #9
Hello, follow up question;
can we consider lesser know wheel brands as quality wheels as well?
Halimbawa gusto mo makatipid ng konte, well given na mahal tlg yung mga legit reputable brands. How about yung mga ibang brand? Okay bang alternative yung mga ganon?
Pamilyar ba kayo sa Auto Bandados sa may Evagelista? Legit ba mga rims don?
- 53,004
March 5th, 2018 12:04 AM #10
Nagmahal na talaga but MMPC compensated naman the feature due to the following upgraded items: 1....
2014 mitsubishi montero
