Results 1 to 10 of 10
May 2nd, 2013 08:02 PM #1
Help naman mga sir, I'm about to change my 2 front tires (215/65/16). Naisip ko kapalan at lapadan ng konti ung ipapalit (235/65/16), Magkakaissue ba to or ok lang? Also if ever pwede, san mas advisable ilagay yung masmakapal, sa front or sa rear? Thanks in advance! :D
May 2nd, 2013 08:38 PM #2
Di lang width ang magbabago sa tire mo. Pati yung sidewall height din.
Di na magiging accurate odometer mo. Most probably yung fender liner kakainin din.
Sent from my Nexus 7 using Tapatalk HD
May 3rd, 2013 10:49 AM #4
Yan din balak ko gawin. Wala naman siguro problema as long as pareho pa rin rolling circumference mo para di apektado yung odometer at speedometer mo. Syempre yung bago dun mo lagay sa kung alin humahatak, fwd o rwd b.
May 3rd, 2013 11:28 AM #5
^ ^ ^ Add ko lang...
215/65-R16 vs 235/65-R16 Tire Comparison - Tire Size Calculator
HTHLast edited by joemarski; May 3rd, 2013 at 11:31 AM.
May 3rd, 2013 02:46 PM #6
Depende sa sasakyan. Tsaka depende kung mas malapad ang rims mo sa likod. Tama sila dapat mag-clear sa fender. Yung odometer naman depende kung saan nakakabit, kung sa harap o likod, depende kasi sa manufacturer. Yung harap ko 205/55/16 yung likod 225/50/16 ayos pa naman. Normally kasi 15 lang yun.
May 3rd, 2013 04:21 PM #7
May 3rd, 2013 05:06 PM #8
Hence, the only issue is the Width. Other dimensions are almost negligible, having less than 1% diiference from the stock.
Check mo na lang sa actual at baka may sumayad. Baka nga kainin 'yang fender liner.
Ayos rin ang malapad na gulong... Looks, siyempre depende rin sa sasakyan kung bagay o hindi.
But above all (sa akin lang naman) > > > GRIPS.
The wider the tires, the bigger road surface it grips. Driving is easier and safer.
May 3rd, 2013 05:24 PM #9
contrary to your grip sir.. parang may point nga yung explanation dito.
Car Bibles : The Wheel and Tyre Bible Page 3 of 4
May 3rd, 2013 09:31 PM #10
Actually its tested na for my ride ( X-Trail) na hindi sasayad sa fender lines yung ganun kalapad kasi may nabasa nako sa forums na ganun yung gamit. Concern ko na lang siguro kung saan dapat ilagay yung masmalapad at bago, front or rear? Ayoko pa kasi palitan lahat ng gulong, sayang yung 2 sa rear 80% thread life pa.
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
