Results 1 to 10 of 11
November 21st, 2003 01:56 AM #1
I just went through mud this morning. After going through a carwash, yung tires ko naging bluish sa may edges... ano to??? di ba delikado yung ginagamit nila na panlinis? pag ako naman ang naglinis ndi naman nagiging blue ah! :freak:
November 21st, 2003 02:31 AM #2
That's normal, rubber reacting to some of nature's own chemical. Normal lang yan, nothing to be worried about. Just apply tire dressing aptly all over the sidewall and those bluish hues will eventually disappear.
November 21st, 2003 02:37 AM #3
ganyan din sa kaibigan ko... lagi blueish tires nya twing nakikita ko but ndi namin pinapansin.. hehehe
November 21st, 2003 02:59 AM #4
umm...bakit saken naman pag nililinis ko di naman lumalabas yung bluish? does it mean that the detergent their using is not car shampoo?
November 21st, 2003 08:50 AM #5
Kasi nung nililinis mo di naman ganun karami ang putik para maging bluish yung rubber. O kaya naman, di pa ganun katagal nababad yung putik sa goma.
November 24th, 2003 12:22 AM #7
eh medyo matagal tagal na nakababad sa putik? or actually matagal tagal na dry yung putik na nkakapit s tires.yun kaya ang reason? nag react ang rubber sa putik? delikado ba yun?
:confused:
November 24th, 2003 04:14 PM #8
As we have said in our previous post, it is normal and perfectly safe.
You better take some aspirins before going to sleep to avoid getting too paranoid with those blue hues.
November 25th, 2003 01:48 PM #9
Don't worry, it is normal. Ganyan ako parati kapag galing sa bukid. Just relax and watch TV. :D
November 27th, 2003 04:38 AM #10
pwede po pa paint ng black... tapos wax and buff and seal mo hehe jk po
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
