Originally Posted by innova2013 +1 195/55r15 will give you better fuel mileage due to smaller rolling circumference than your stock tire size and better grip due to the wider size. fuel/km will cost more if the diameter is smaller than the stock..wider tyre means your engine works harder .. Posted via Tsikot Mobile App
View Tag Cloud
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
My car's axle boot is leaking and the mechanic recommended to replace all (inner and outer). Kasi...
Have good situational awareness. But even then, you cannot anticipate everything. When it's your...
with this incident I will be now more careful in going places wherein there is no concrete barrier...
Yes, it's been established that the root cause was driver error. However, as with any...
Enter your email address:
Delivered by FeedBurner
