Results 1 to 8 of 8
    May 2013
    Hi Guys,
    Gusto ko palitan yun stock tires na 185-65R15. Pwede ba yun 195-60R15 or 205-60R15? Iniisip ko kasi yun handling saka fuel efficiency. Thanks!
    Aug 2008
    You can also add 195-55-15 to your option. The stock tire of my vios is also 185-65-15, but I changed to 195-55-15 for better grip (fatter) and stance (lower profile) plus the rim guard.
    Posted via Tsikot Mobile App
    Aug 2013
    Quote Originally Posted by crave View Post
    +1
    195/55r15 will give you better fuel mileage due to smaller rolling circumference than your stock tire size and better grip due to the wider size.
    Quote Originally Posted by innova2013 View Post
    +1
    fuel/km will cost more if the diameter is smaller than the stock..wider tyre means your engine works harder ..
    Aug 2010
    Quote Originally Posted by gutz_3110 View Post
    Hi Guys,
    use tire calculator
    Dec 2002
    yan din size na pinalit ko dati sa lumang oto, 195/55R15 kaso ngayon nauso na ang r16/r17.
    May 2013
    Quote Originally Posted by trucker111 View Post
    use tire calculator
    thanks trucker111!
    i just used a tire calculator, you have to take in consideration of the stock tire size pala. akala ko basta salpak lang ng salpak ng maski ano basta maporma hehehe kelangan ma off-set ng replacement tire mo yun stock otherwise, may impact na malaki sa odo and speed.
    Hi Guys,
    depende sa oto yan eh..... some cars like the smaller Getz, i10, Picanto, Celerio and Mirage may not be able to handle the 195/55/15 route.... Ang maximum dyan is 185/55/15 dahil labas fender na yung goma if ever.
    for bigger cars like lancers, altises, sentras, the norm is 195/55/15.
    i think 195/65/15 is for Mitsu Adventures. Yun ang stock nya eh.
    195/60/15 is still ok though for sedans as stated above. kaya lang medyo mataba na and may malaking margin of inaccuracy na sa speedo mo.
Alternative Sizes to (Stock) Tires
