Results 1 to 10 of 10
- Aug 2006
- 7
August 23rd, 2013 10:09 AM #1patulong naman po. i just purchased 1991 kia cd5. battery got discharged, pulled it out and recharged it for 4hours. when i placed it back, suddenly horn started aloud continously and had to take out the negative connection on the battery to stop it. disconnected the horn switch thinking that switch maybe shorted, placed the negative connection back on the battery. silent for a while, then came this loud continous horn sound again. ano po kaya ang nangyayari? i placed the battery back after recharging it after the heavy rains(di ko alam kung may koneksyon ito) car doesnt have any alarms/central lock at all. by the way, the horn switch is modified by the previous owner. its been mounted on the dashboard w/a switch as the previous owner got a momo steering and not able to attach the horn. napansin ko lang w/the horn, kahit patay yung engine eh gumagana yung horn. tama po ba to? o dapat nakakabit siya sa ignition switch para mag-work lang sya kung bukas yung engine? but right now, really need help regarding the horn. ok lang ba na disable ko yung horn speaker just to make the car start running again? need your great minds here mga tsikoteers, patulong naman po. THANK YOU VERY MUCH IN ADVANCE !
August 23rd, 2013 10:36 AM #2
definitely, grounded yung connection ng horn.
pa check mo sa electrician.
in the meantime, disconnect mo muna siguro o tanggalin mo muna yung fuse.
- Aug 2006
- 7
August 23rd, 2013 11:11 AM #3
- Jul 2011
- 1,711
August 23rd, 2013 11:35 AM #4paayos mo na din sa electrician ung wiring ng busina mo, pili ka ng location kung saan mo gusto ilagay ung horn swich.
- Aug 2006
- 7
August 25th, 2013 01:40 AM #5Thank you bosing! will do. first project car ko kasi to. still trying to learn the parts of the cd5. di ko makita yung fuse ng horn. may mga nakita akong mga fuse lower left side ng stirring wheel, pero walang nakalabel na horn. dinisconnect ko na lang yung wire connecting directly sa dalawang horn speakers. napatakbo ko yung sasakyan, kaso everytime nagsignal light ako, namamatay yung engine hanggang sa totally ayaw na talagang mag-start. though kacha-charge ko lang nung battery, na-drain na siya agad. normal kaya yun? MARAMING SALAMAT SA MGA NAGRE-REPLY
- Jul 2011
- 1,711
August 25th, 2013 06:07 AM #6tignan mo sir ung battery terminals mo kung umiinit, baka maluwag lang higpitan mo, kung madumi linis lang po.
pag ok naman ung terminals, pa-check mo sa battery store ung battery mo baka malapit ng mag end of life.
August 25th, 2013 06:28 AM #7
Does it have an alarm? Some alarms goes automatically into panic mode when the battery is reconnected.
- Aug 2006
- 7
August 27th, 2013 12:05 AM #8
- Aug 2006
- 7
August 27th, 2013 12:11 AM #9
wala naman pong alarm. very basic/stock yung kotse. meron po bang factory installed na alarm ang kia cd5 91? iniisip ko nga baka may electrical shorts eh. di ko lang mahanap fuse ng horn wala dun sa fuse panel sa ilalim ng steering wheel. check ko uli pag day-off ko. Thank you bosing!
- Aug 2006
- 7
August 10th, 2015 02:33 PM #10sencia na po, was not able to close this issue. I went to a car electrician, my horn got replaced, everything went fine. I later change the battery as well. THANKS to all who replied!!!
reminds me of the Revo vs (1st Gen) Innova
