Results 11 to 15 of 15
- Jan 2008
- 337
August 23rd, 2008 05:23 PM #11[SIZE=2]Indeed, CRDI engines do smoke but they are almost invisible. I havent seen CRDI smoking in white, usually its black and happens only during intitial-high revving of engine. They say this is normal because of engine's EGR that produces more heavy particulates(soot) inside exhaust pipe that when accumulated would give black smoke on initial or sudden engine revolution..Try cleaning your exhaust pipe with garden hose and water then observe if it will dissappear(temporarily). Maybe for permanent solution, try installing water methanol injection to burn the soot, decrease exhaust gas temp, and lessen particulate buildup..
[/SIZE]
- Aug 2008
- 18
- Dec 2007
- 132
August 24th, 2008 12:24 PM #13Maybe kia dealers does not use the proper motor oil. JUst like in vgt crdi engine of carens, the manual indicate that carens equipt with catalyzed particulate filter(CPF) should use acea c3 classification oil , but they use only petron sl/cI oil for all kia car. When I checked the Petron trekker motor oil with API spec of SL/CI ,it does not have acea c3 which means it did not meet oil requirement of kia. Without proper use of oil , the exhaust may clog the inlet pipe of the filter causing it to be inefficient and eventually destroy the engine.
August 25th, 2008 06:25 AM #14
- Mar 2019
- 1
March 12th, 2019 09:56 PM #15how about po sa kia carens, newly top overhaul cya tapos pinalitan na yung fuel filter ung egrna clean n din pati ung airflow nya, tas ilang araw lang d pa gaanong nagagamit umaandar pero namamatay pag patatakbuhin na tapos ang itim sobra ng usok nya.... pano po kaya ito ano po bang dapat gawin
Xiaomi E-Car
