nabastos yung koche koninakaw po yung left side mirror, yung mirror lng po mismo. tinatry ko siya dun sa side mirror adjuster gumagana pa naman po. makakabili po ba ako ng mirror lang?
please help nahihirapan po ako magdrive
Yes, you can. There are shops in the Banawe area that specialize in this.
After having that done, you might want to have your mirrors etched to prevent future thefts.
sa pinakamalapit na auto supply kung saan nawala yung side mirror mo. kung swerte ka, baka yung mirror mo mismo ang makuha mo.![]()
Unfortunately walang brand new of the glass lang. Kasama buong sideview mirror assy.![]()
ay ganon po ba? cge po, maghahanap po ako sa banawe later kapag wala po talaga bibili nako ng buong mirror assy yung may headlights na po tapos papalagyan ko ng lockgrabe po kasi kagabi lang nangyari.
If you have an 03 Crosswind, they have lots of the plastic parts that attach to the motors, pero non-original glass, so it sucks. At least you can still use the window motors.
Have those mirrors etched ASAP. Look up Doc Otep here on the forums (username: OTEP ), as he sells mirror cages to protect them... these cages integrate into your current housing, so they don't look like crap like most do.
And, friendly advice, as a fellow Crosswind owner, check your corner-lights... those are also easy to steal. You may want to add extra screws or silicone sealant to glue them in place.
naganyan na ko at both sides pa, i went to banawe kumausap lng ng mga freelancer dun.. 600 each last year after nun palagyan mo na ng protector 650 each ata un sa mga reputable autoshop sa banawe din.
Laging nababastos yung mga kotse namin na nakapark sa labas dun sa isang bahay namin na walang indoor na garahe. Sa huli pinadikit namin permanently yung side mirror ng Escape (not sure how they did it basta di na matatanggal pero gumagana pa yung motorized adjusters. Dun naman sa Accord at Revo, nilagyan ng parang goma na cage (not sure what its called) basta yung nililibot yung surrounding ng side mirror na kulay itim.
kuya benzmizer, magkano po yung kapag buong assy na yung may signal lights narin? kahit estimated lang po![]()
ninakawan ako last month 2 side mirrors sa banawe mismo. may sidemirror guards ako pero natunungkab nila. why? kasi silicon lang inilagay nila. ipalagay mo yung steel epoxy and best, metal yung kuhain mo na guards and not the plastic type.
