Results 1 to 10 of 14
- Jan 2011
- 108
August 18th, 2011 07:18 AM #1nabastos yung koche ko ninakaw po yung left side mirror, yung mirror lng po mismo. tinatry ko siya dun sa side mirror adjuster gumagana pa naman po. makakabili po ba ako ng mirror lang? please help nahihirapan po ako magdrive
August 18th, 2011 09:00 AM #2
August 18th, 2011 10:07 AM #3
Yes, you can. There are shops in the Banawe area that specialize in this.
After having that done, you might want to have your mirrors etched to prevent future thefts.
August 18th, 2011 10:32 AM #4
sa pinakamalapit na auto supply kung saan nawala yung side mirror mo. kung swerte ka, baka yung mirror mo mismo ang makuha mo.
- Jan 2011
- 108
- Jan 2011
- 108
August 18th, 2011 03:04 PM #8
Unfortunately walang brand new of the glass lang. Kasama buong sideview mirror assy.
- Jan 2011
- 108
August 18th, 2011 03:08 PM #9ay ganon po ba? cge po, maghahanap po ako sa banawe later kapag wala po talaga bibili nako ng buong mirror assy yung may headlights na po tapos papalagyan ko ng lock grabe po kasi kagabi lang nangyari.
August 18th, 2011 03:32 PM #10
If you have an 03 Crosswind, they have lots of the plastic parts that attach to the motors, pero non-original glass, so it sucks. At least you can still use the window motors.
Have those mirrors etched ASAP. Look up Doc Otep here on the forums (username: OTEP ), as he sells mirror cages to protect them... these cages integrate into your current housing, so they don't look like crap like most do.
And, friendly advice, as a fellow Crosswind owner, check your corner-lights... those are also easy to steal. You may want to add extra screws or silicone sealant to glue them in place.
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
